for Limey
for Limey
Limey are you around? I see you are signing in as a guest and remember you were having problems with your password. I need to ask you something. Let me know if you need me to reset your password.
Guest
Post by Guest »
Im still here without a password, i try to remember to put the limey at the bottom of my posts, but sometimes i forget :(
I had a real change around of my setups, ie I got 2 pcs and 4 hdds between them, this pc has 2 120gb hdds, so as you can imagine i have a lot of stuff on the pcs and I am really not sure which pc or hdd has my password details for this site, also I have no idea which email addy i used, I will find it eventually or maybe register as the real me :)
Guest
Post by Guest »
When I first registered as guest, ie i registered that user name i was using my thailuts@mail.com addy, I still use that one.
The Limey
changed password
Limey: I updated the password and sent it to you on the email address you referenced above. Can you try logging in with the updated password?
the limey
Post by the limey »
Cheers Dozer that works a treat :)
