I got downgraded today
![Confused :?](./images/smilies/icon_confused.gif)
I log on using google .UK wondered if that had any bearing
I think we all had similar problems ... Dozer was aware and all appears to be back as it should be now. Let us know if not.geordie wrote:I got downgraded todaycould not access the forum for most of the day
it would not even attempt to connect or came up with sql error too many users ? the net or the forum ?
Same here Dozer, had a few problems, everything seems to be back to normal againMGV12 wrote:I think we all had similar problems ... Dozer was aware and all appears to be back as it should be now. Let us know if not.geordie wrote:I got downgraded todaycould not access the forum for most of the day
Far from it. Many problems this morning and it's completely impossible to upload photos. First they're invalid, then the size is inderteminate and then the board attachment quota has been reached.sirineou wrote:had a few problems, everything seems to be back to normal again
I am only kidding about the god thing,geordie wrote:if its any help its also told me memory full wait it will take 60 seconds for host to clear memory ?? something like that anyway after waiting 20 mins i knew it was lying![]()
I did not start a new thread because i didnot expect it to persist also usually if this pc plays about its after it,s upgraded itself my son alway fobs me off with the changes as _software upgrade,sits a lot better this evening anyway thanks Dozer
sirineou had it been me alone it could have been fobbed off as ""lost the plot" Fred knows how they work
Liar you should really see someonesirineou wrote: I am only kidding about the god thing,
Unfortunately you are right about the Liar part but not right about the god partgeordie wrote: Liar you should really see someone![]()
Holding down the left mouse button while dragging the cursor over the portion of script you want to copy, would high-lite it blue, then right click the mouse, while the cursor is over the high-lited script and you will get a dialog box with a number of options, one of them would be COPY now this script is copied in your computers temp memory . to access that copied script, all you need to do is to again Right click the mouse in the area you want to Paste the script , and the same dialog box as before will open, this time choose the PASTE option. you can do that in the reply window, or if you want to save the script you copied, you can paste it in to your word processing program, or your windows note pad.geordie wrote:Bing useless with computers as well as semi illiterate i have problems i though a hilight was something the wife had in her hair ? then realised it meant colour it blue and copy i have seen people do it loads but i always lose the bit it copied ? proof above i managed to copy the {quote} bit then lost it again happily i just did a rather long post that went through instantly but i did initially wonder if the fact i use google UK had any bearing on it even cheching peak time,s scholl tipping out in uk or here coincidentally it did play up at those times but usually it just sloes things down a little not kick me into touch
