Wood Wool Cement Slabs
Postby MrRee » Sun Jan 03, 2010 7:39 pm
Thought I'd post some good info for posterity. These materials are available in Thailand and nearby countries. They can be ordered, cut, and verified to fit at the manufacturer prior to delivery. They can be numbered for assembly on site by unsophisticated workers following a matched numbered assembly plan.
http://www.eltomation.com/Eng/Publicati ... 20WWCB.pdf
http://www.hdm.lth.se/fileadmin/hdm/BI_ ... nd_Use.pdf
Pictures of actual application can be found here: http://www.eltomation.com/Eng/eltoapptumb.html
Please move if not in the correct forum.
MrRee
Re: Wood Wool Cement Slabs
Postby geordie » Mon Jan 04, 2010 12:19 am
used a similar product some years ago good fire resistance very heavy to handle knocks ten coulors of c..p out of your tools and the ensuing dust storm not good either does not like screws either pull out easily however more robust than most sheet material also more expensive
Users browsing this forum: Bing [Bot] and 1 guest
