CPAC: All you need to know about it and were too afraid to ask.
Where and how to buy.
Concrete is one of the materials you will spend most money on so it's really worth looking into the options. Here you have up-to-date info on prices and where to buy. For what to use for which jobs, the other posters have provided adequate information.
Ready mixed concrete is made and delivered by anyone who has a yard and a cement mixer truck.
NOTE:
CPAC is a brand name which has become generic for Ready Mixed Concrete, just like Hoover for vacuum cleaner, Tempo for pocket tissues, Q-Tips for cotton buds, Kaercher for high pressure cleaner and Biro for ball-point pen.
CPAC vs. hand mixing:
CPAC (Ready-Mix) is a boon - hehe, nice pun on the Thai word for cement
- as it really does save a lot of labour, and this is why you should make it clear with any workmen you hire to build your house or a driveway or a long perimeter wall, whether their labour includes for hand mixing or using CPAC. Note that once you've even mentioned CPAC, they won't have it any other way because 1. They HATE mixing concrete because they don't know - or dont't want to know - how to use shovelsand 2. They know you can afford CPAC. 3. They know that it take three or four times longer to do the same job by hand mixing. The phases of building a normal sized house (except for laying the roof tiles) never usually take more than about two days each. Thai people get bored very quickly by days of repetitive work.
A cubic meter of CPAC works out about
double the price of hand mixed concrete, but you must remember that the supplier also has to amortize the cost of his truck and provide a driver (sometimes two) who will stay on the site until the job is finished. Delivering CPAC is not just a question of arriving ad dumping 10 tons of concrete for you and your changs to spread around the place. See the prices below.
Planning: Getting the stuff dumped exactly where you want it is not as easy as it may sound. If you made the mistake of building all your interior walls before pouring the floors, you will have to organise your labour in relays to wheelbarrow it to where it is needed, and planks will have to be laid across your sand/wire-mesh to push the barrow; it sometimes takes two men to move the barrow, one pushing, one pulling. This planking all has to be shifted again and again as the work progresses. At the end of the day you will feel that you have defeated the object of having CPAC delivered.
When planning your house, be absolutely sure that a large truck will be able to back up to within a maximum of about 5m of where you will dump. They use large diameter blue PVC pipes cut in half longitudinally for chutes and it is almost impossible to send the stuff round corners.
Time factors: Five experienced workers will lay the 15 or so cubic metres needed for the floor of an average house (ca. 150 sq.m.) in one full working day. If you made the mistake of building all your interior walls before pouring the floors, like Jazzman did 25 years ago in Germany it will take up to 50% longer or more.
One load of CPAC will remain liquid in the lorry for about two hours on site plus the time on the road. Calculate well, and have enough people to spread it, a pile of it left standing will start to get stiff in less than 30 minutes. Get extra labour for the day if you think you will need it: at 150 baht per day per man it's not worth economising on, and risking wasting several thousand baht's worth of CPAC because you can't get finished before it hardens.
Delivery: A big job like a floor or a long concrete drive (say about 150 cu.m.) will require 2 full loads of a ten-wheel truck (about 7 cu.m per load). Some firms, particularly village building supplies outlets who make CPAC as a sideline, have the smaller 6-wheel trucks which hold 3 cu.m. These are fine for filling footings or pathways.
Quantity: How much concrete do I need? It is surprising how often this question pops up on web forums. It should be fairly easy to work out. A volume is calculated by multiplying the length by the width by the depth (height): L x W x H, or it was when Jazzman went to school, but with the advances in technology over the last 50 years, anything could have changed since the Egyptians got it all worked out 5,000 years ago. If your floor pan is a highly irregular shape with curves and things, get your labourers to work it out, you'll be surprised - they can can do it (after squatting down and much debate).
Setting: Correctly mixed and laid concrete should be stiff enough to walk on without leaving footprints within 2 hours, but it's not recommended. If you see concrete with dog, chicken or buffalo footprints in it, there was either something wrong with the mix, or nobody could be bothered to hang around for a while to shoo them off
Contrary to what some people believe,
concrete doe not dry, it
cures. The water doesn't go anywhere, it actually becomes one of the ingredients in the chemical compound which results. CPAC is made with more water to keep it elastic for longer while it is worked, but it should not be too sloppy. There is the famous cone test, but generally, when laid concrete is smoothed over, it should be firm and and have a matt sheen to it. Pushing your fist down through it should be difficult. If it's easy, you will feel the looseness of the stones of the aggregate and you will notice that the higher layers are just water and sand. You'll end up rushing to get more dry aggregate thrown into what has been laid to give it more density and poking it down with a stick, so be sure to have a pile of gravel handy, as this often happens with CPAC - the Thais tend to put too much water in it. Over dilution - and watch out for this when they get going with the garden hose to flush the last bits out of the truck - will destroy the chemical process and all you will get is a mess of dry powdery gravel and sand.
The fact that it may be hard after an hour or two, is only the beginning of the process. Concrete needs about 28 days to fully cure, and the hardening process can continue for weeks or months. In a tropical climate it is crucial not to let the concrete dry out. As soon as it is hard enough not to absorb any more water, it should be sprayed (not soaked) with a hose then covered with sacking which should also be sprayed. The sacking should be kept moist for several days, and no structural work should be carried out on the concrete.
Shuttering (formwork) can be removed after a day or two for flat floors and footings, and should be left on pillars and beams for several days, but it is best not to disturb it at all until it becomes absolutely necessary to remove it for doing other work.
How much cement powder? Yes it is true that in Germany we do go OTT with most things, - the bodywork of a Merc is almost bulletproof when it leaves the production line.
About 6 bags per cu.m is the norm. Adding more does not necessarily increase the strength, after all it
is only supposed to be a binder for the hard stuff: the sand and the gravel. Cement powder mixed on its own with water and left to go hard is not strong stuff. Look at those left-over sacks of cement that have gotten wet, and how crumbly the cured powder is.
What does add to the strength is the quality of the cement powder. Here in Thailand it is usual to use the best in CPAC, because CPAC is mostly used for constructional concrete and large spans. They use Portland, which they call
boon daeng because of the red lettering on the bag.
Where to buy: Every amphoe (district) town, and most larger villages will have someone who will deliver CPAC. It is not stuff which is transported dozens of miles to the customer. You've probably driven past lots of CPAC depots without realising it. They also make concrete pillars and fence posts and the concrete rings for septic tanks too, so where you see a yard full of those things lying around, that's the place to stop and ask.
Cost: The cost fluctuates with the cost of vehicle fuel. Transport is a big factor for sand, gravel and cement powder are heavy stuff. It has to be delivered to the CPAC depot, and then it has to be mixed and delivered to your house. You will have noticed that all major construction sites like bridges, motorways, skyscrapers have their own CPAC plant with their tell-tale silos for the cement powder and sand and gravel mountains, and particularly typical British housing estates (because the UK is still the only place in the world where there is no tradition of buying a plot of land and building your own house - mainly because the government has made it practically impossible for Otto Normal Burger to get through the red tape. The building developers all wear clunky gold jewelery and cuff-links, and by coincidence, so do the officials in the town hall's planning department.
House prices in Britain are totally out of proprtion to the actual cost of building them, particularly where the developer only has to pay the architect for one design and then buys up some cheap farmland and puts up rows and rows of identical modern residences with fake Edwardian poticos (Don't they look nice? But the gardens behind them are hardly big enough to hang out the washing). It is
no coincidence that many UK millionaires nowadays have Irish sounding names.
After the enormous world-wide fuel hikes in mid 2006, prices at the time of this posting (mid December 2006) had settled to around
1,300 to 1,550 Baht per cubic meter depending on the requested quality of cement to be used. CPAC is generally slightly more expensive (in our experience) in the cities than in rural areas. The supplier isn't actually making a vast net profit, for one thing, he is not buying the cement in loose bulk. He's ripping open 40Kg sacks just like you would be.
Everything else you need to know about CPAC in Thailand is here
http://www.cpac.co.th
There is more about cement on Dozer's main page at
http://www.coolthaihouse.com/infobasicmaterials.htm
Hope all this helps. Feel free to contact Jazzman or any of the other posters for more advice.
Jazzman
