Udon Thani Area - Electriction
- sources & prices
Re: Udon Thani Area - Electriction
Postby kmanonmaui » Fri Sep 15, 2017 5:23 pm
Sometimewoodworker wrote:
kmanonmaui wrote:
Concerns:
Other Item of Interest, but not of great importance right now: I plan on placing a generator large enough to power the key needs of the house on property, manual cut-over. If anyone has some thoughts/recommendations on this I would appreciate it also.
Make sure that it's in the electrical plan.
Set it up for auto start and auto switching. You will quickly find manual operating start and switching gets boring.
Ah...finally made it here. Sadly, my basement does have about 3 cm of water in it. But, its been raining like hell since I got here last week and without any pumps installed yet I'm not that surprised.
Now starting to look at matters that may take a bit of time and the generator has come up again. From readings, I "hear" that water cooled is more quiet, but not so available. I've ample room on the property to place the generator 20+ meters away from the house...but much more and I'll have my neighbors hearing more of the generator noise than I will, which wouldn't be nice.
Really would like a "small business" sized generator, despite the extra cost, to provide enough to run the home with multiple a/c splits as well as other items without issue. Problem I am finding is that "I cannot seem to locate a 20k KW plus level generator in Thailand". Am I just not looking hard enough or not looking in the right places? This is my "ideal unit", though air-cooled, but no B&S dealer in Thailand that I can find: http://apelectric.com/briggs-stratton-4 ... er-switch/
kmanonmaui
Postby Klondyke » Fri Sep 15, 2017 6:42 pm
If just for your house (and not for all neighbors in the soi), perhaps you should first observe what everything is running in your house with excluding some not very important consumers when the power failure occurs. Normally, unless you do not feed some workshop machines, some 2 - 3 kW should be enough. And that is available in Thailand. And surely much quiet than such 20 kW machine.
Postby kmanonmaui » Fri Sep 15, 2017 7:08 pm
Klondyke wrote:If just for your house (and not for all neighbors in the soi), perhaps you should first observe what everything is running in your house with excluding some not very important consumers when the power failure occurs. Normally, unless you do not feed some workshop machines, some 2 - 3 kW should be enough. And that is available in Thailand. And surely much quiet than such 20 kW machine.
Solid advice and much appreciated. Would still like larger than 3 kW, maybe 7 kW. Is there a particular make/model available in Thailand that anyone could recommend? NG over Diesel? Any other advice/recommendations always appreciated.
-k-
kmanonmaui
Postby Wanderer555 » Sun Jun 02, 2019 7:21 pm
kmanonmaui wrote:- Outlets If cost is not an object, what do you recommended? (I assume GFI on all exterior/bathroom/potentially wet areas).
You should use the correct worldwide naming rather than the isolationist US terms :roll: :lol:
FYI: The GFI (GFCI) also known as a RCD(RCBO) was invented by Charles Dalziel a professor of Electrical Engineering at UC Berkeley, California in the United States of America. He received a patent on the invention in the early 1960's.
Like many other great CAL professors, his work was part of our freshman year introduction to the CAL Physics department.
In short, GFI is hardly an 'Isolationist' term, it is more about whoever invents it gets to name it :)
Of course, others are free to call it whatever they want ...
Conversely, while in other parts of the world, I have no problem using the term RCBO if that is the term that is being used.
Cheers! :)
Wanderer555
Return to electric
