Mains water, water Tank, pump and filter
Anything to do with the subject of water or plumbing. Any type of well (hand dug wells, drilled wells, etc.), plumbing (but not swimming pools) or any other discussion related to water.
Postby Caps » Sun Jan 28, 2018 10:18 am
I am starting to plan a build in a village near Chum Phae, the area where we are going to be building has a mains supply which seems relatively constant. The house will house 4 to 5 people. I was thinking of putting a 2000/3000 litre tank a pump and a filter, these will be between the mains water supply and the house. I am not sure about the mains water pressure
The filter is not to make the water drinkable, its just to take a lot of the crap out of it as I have found a lot of green gunge in the twin tub we bought awhile ago and I dont want the same thing happening again when I my new washing machine or for it to interfere with the shower etc.
Has anyone got any ideas on the best way round to but all this together? i.e. Filter first or last etc.
What is a recommended water pump size? It will have to push the water up to 2 meters high as we are building on concret pillars.
Is the water tank size adequate?
Is there anyother relevant info for what I may need to do
Wayne
Caps
Re: Mains water, water Tank, pump and filter
Postby Klondyke » Sun Jan 28, 2018 12:19 pm
Caps wrote: I was thinking of putting a 2000/3000 litre tank a pump and a filter, these will be between the mains water supply and the house. I am not sure about the mains water pressure
Wayne
Nothing between the mains and your storage tank should be installed. You are not allowed to pull anything directly from the mains pipes. (Recently, there was here a thread about that).
The tank will get slowly filled in during nights, so you will be able to take the water out by the automatic pump from the tank and push it thru a filter into your house.
There are plenty of automatic pumps (Mitsubishi, etc) at every hardware shop, any smaller size will be OK for your house and garden.
The filter should be something like this:
Postby Klondyke » Sun Jan 28, 2018 12:21 pm
^ Every village "chaang papaa" will know what you will need and how to install it. Just let the wife ask around.
Postby Caps » Mon Jan 29, 2018 1:40 am
Wayne
Thanks Klondkye, so the layout will be, mains water to my water tank, then the pump from the water tank and then the filter before the the pipe goes into the house?
Wayne
Caps
Postby Sometimewoodworker » Mon Jan 29, 2018 7:31 am
Caps wrote:Thanks Klondkye, so the layout will be, mains water to my water tank, then the pump from the water tank and then the filter before the the pipe goes into the house?
Wayne
That is the generally used system. There is one point that you may want to consider and that is that if the water supply pressure is usually, or sometimes, good then you could have a pipe that will bypass the tank.
Standard Thai labelled layout
English labelled layout
The exact location of your filter will be dependant on the clarity or otherwise of your incoming supply.
It could be placed between the pump and pump valve 2, then you would not filter the direct from village supply. This is only works if you have a pressurised filter.
If you want a non pressurised system then the layout becomes a bit more complicated.
Postby Caps » Tue Jan 30, 2018 12:22 am
Thanks Sometimewoodworker, yes I was thinking of putting the filter beween the pump and the house. I will have to ensure I get a pressurised filter...any suggestions? Again I dont want it filtered for drinking, just to make it decent water so we dont get things like washing machines and shower clogged up with green slime etc
Wayne
Caps
Postby Klondyke » Tue Jan 30, 2018 7:37 am
The pressurized filter is the blue thing on the previously enclosed picture, As I said, any plumber in the village will know where to get it from, price 8,000 - 12,000 Baht. Or you can look in Global House or similar, they have it too, even in stainless steel.
Postby Klondyke » Tue Jan 30, 2018 7:47 am
Speaking about "green slime"? That's quite unusual in municipal water system. Rather you should get a rusty water (Saanim), if the water source is underground.
If something green appears, it could mean algae presence. That could be a case when the water is taken from a large surface pond without much treatment.
Anyway, whatever a filter/pump system you will install, a frequent addition of a small amount of chlorine into the storage tank is advisable. To kill bacteria in the water standing over long time period without much move movement, avoiding algae growing as well.
Postby Caps » Tue Jan 30, 2018 3:19 pm
Thanks for the answers guys.
I will have a look in to the adding the Chlorine to the water tank
wayne
Caps
Return to water and plumbing
