Bang Saray House Build
Re: Bang Saray House Build
Postby rchapstick » Sat Aug 19, 2017 6:40 am
Next came the second floor cement pour. They also did the cement for the stairs and the upstairs columns.
rchapstick
Postby rchapstick » Sat Aug 19, 2017 6:43 am
rchapstick
Postby rchapstick » Sat Aug 19, 2017 6:46 am
rchapstick
Postby rchapstick » Sat Aug 19, 2017 6:50 am
lots going on at once now. Framing for the roofs, and starting to put the qcon block in. We used 20cm block for exterior walls, and 7cm block for interior walls. Then had SCG come and do the roof. Again, we had the Top Hat aluminum frame, and the Cool Roof ventilation system.
rchapstick
Postby rchapstick » Sat Aug 19, 2017 6:54 am
rchapstick
Postby Sometimewoodworker » Sat Aug 19, 2017 6:56 am
rchapstick wrote:By the way, is there a procedure for uploading pictures more than one at a time? This process is painful!!
There are technical problems to upgrading the system software . If these can be overcome then it will be possible at some time in the future.
Postby rchapstick » Sat Aug 19, 2017 6:57 am
rchapstick
Postby rchapstick » Sat Aug 19, 2017 7:02 am
Really started to look like a house at this point! But sadly, only half way done.
Roof getting finished, and the electric rough-in next.
rchapstick
Postby rchapstick » Sat Aug 19, 2017 7:04 am
rchapstick
Postby rchapstick » Sat Aug 19, 2017 7:08 am
In the next picture, you can see the vents on the crown roof tiles
rchapstick
Postby rchapstick » Sat Aug 19, 2017 7:13 am
rchapstick
Postby rchapstick » Sat Aug 19, 2017 7:19 am
More electric work, ceilings, rendering and initial painting outside, and starting the tile work.
rchapstick
Postby rchapstick » Sat Aug 19, 2017 7:24 am
rchapstick
Postby rchapstick » Sat Aug 19, 2017 7:30 am
rchapstick
Postby rchapstick » Sat Aug 19, 2017 7:37 am
rchapstick
