saltwater chlorinator
Postby stevenff » Tue Jul 18, 2017 11:35 am
Hello,
I am thinking of bringing a Hayward salt water chlorinator from the US to Thailand but I am concerned about the electrical wiring difference. Would it be a problem? Thanks for any response.
stevenff
Re: saltwater chlorinator
Postby schuimpge » Tue Jul 18, 2017 1:00 pm
Not experienced with pool equipment, but in general, if the chlorinator is wired for 220v, then there's usually problem with wiring.
Be aware that this is Thailand and you should be sure about the wiring having been put in place properly at the place where you want to install the chlorinator.
Very good link with lots of info: http://www.thailandguru.com/electricity ... iland.html
Postby sjeng » Tue Jul 18, 2017 1:53 pm
I bought a hayward pump and filter some years ago they are wired for 220 V or 110 V just have to check before connecting to the grid. its just a small connector which has to be turned around and connected again. READ THE MANUAL and the sticker on the device it will tell you if its installed for 110 V or 220 V.
I think all Hayward poolstuf is constructed in the same way. GOOGLE for the chlorinator you want might help also.
sjeng
Postby stevenff » Thu Jul 20, 2017 12:18 am
Thanks guys!
stevenff
Postby Rdteth » Wed Jul 26, 2017 11:17 am
220 V should now be 230V. Years ago already. Although in thailand I never see that.
USA used to be 110V. Therefore you could not use stuff from there without some extra convertor.
Nowadays electronic devices have powersupplies going from 90 to 240V, at least from "reliable" companies.
So be sure to check the stickers on your device. If they say 110V you CANNOT use them straightaway here in thai.
Rdteth
Postby jazzman » Mon Sep 11, 2017 8:55 am
Never buy branded swimming pool equipment in your own country if it has an accredited distribution network in Thailand. Dealers and official service centres will not provide service under guarantee, and some will not provide service later either.
A note about Hayward: It is becoming increasingly difficult to obtain guarantee and/or service for this brand in Thailand. As far as I know, there is not one single official distributor. A friend of mine in Krabi bought 3 Hayward Tristar pumps (one for each of his rental houses with pools) from a Thai distributor, which were all professionally installed with all the correct components in the control boxes and within 6 months they had all blown up due to clearly faulty manufacture and Hayward refused to even acknowledge the problem.
