Workshop and house, Non Sa-At ½ way between KK & Udon
Re: Workshop and house, Non Sa-At ½ way between KK & Udon
Postby MGV12 » Tue Feb 16, 2016 5:44 pm
Sometimewoodworker wrote:
sirgunas wrote:Hi,
Will you be posting an estimated cost of your project?
I maybe starting a project of my own...
Hi
Maybe introducing yourself and what you're thinking of building would be a good idea.
The place for that is under.
http://www.coolthaihouse.com/forum/viewforum.php?f=4
In case you missed it .... he did introduce himself viewtopic.php?f=4&t=5152&p=69812#p69812
Postby Sometimewoodworker » Tue Feb 16, 2016 7:12 pm
schuimpge wrote:Looking good.. Not sure how the support for the crane at the door-side is done, but the other side looks to be a separate column made for it.
At the door-side, looks to be a metal plate that has been tied into the beam/superblock wall, but not very clear from the pictures.
Overall, the more I'm looking at your build, the more I start to plan and look around for getting some land..lol.
I have a nice house and a good amount of area to use as workshop, but seeing the workshop you are building, that's just awesome..
Thanks.
The other 3 points are strong enough, the 2 beside the garden have separate columns the rear H beam is attached to the top reinforced concrete beam.
The door side is tied into the security room reinforced concrete wall, however I'm not very happy with the length of the bolts even though they are going to fill the area with concrete. So I'm getting them to add a support, c section, box section or round post. I don't mind what shape but it will give me peace of mind.
Postby Sometimewoodworker » Tue Feb 16, 2016 7:26 pm
sirgunas wrote:Hi,
Hi
Hi
No I didn't miss that, I've just been a bit busy.
However in answer to Barry if I did have an estimate, I doubt that an estimated cost of my project would be of much help as it is nothing like a standard build. For example the workshop crane if bought from a crane company would have cost 70% of the total spent on grandmums house, the workshop floor is designed to support a car as well as my woodwork machines.
Probably of much more help would be http://bit.ly/GMnewHouse which cost ฿350,000
Postby pipoz » Tue Feb 16, 2016 8:57 pm
I think you will find he has a full height concrete wall behind that connection plate at the door side (the plate is probably anchored back into that concrete wall) as that is where his Nuclear Bunker (Secured Storage Room) is. :lol:
Phil
Postby schuimpge » Tue Feb 16, 2016 10:19 pm
Thanks for pointing out guys. Looked very closely at the pictures and thought the bits rebar sticking out above the blocks was a half finished top beam for the super-blocks... :mrgreen:
To strengthen it. Just move the inside superblock wall at that side of the door about 30cm more to the inside, put rebar in that bigger cavity that you create that way. Fill with concrete and done.
Postby Sometimewoodworker » Wed Feb 17, 2016 8:04 am
This may be more clear
Postby schuimpge » Wed Feb 17, 2016 10:37 am
Sure clear on how strong that safe is..
Now let me save this for future reference to get in easily...lol.
But back to what I wrote on the extra support. This is what I meant for the column and moving the inside blocks 30cm inwards:
STWW House.jpg (44.78 KiB) Viewed 579 times
moving that a bit inwards and close it between outside wall and the inside wall, gets you enough space to put in rebar and concrete for a support column.
Postby jamess1970 » Thu Feb 18, 2016 4:10 am
Sometimewoodworker, you're building a workshop I'd kill for! Is you crane setup going to be powered or just manual movement?
jamess1970
Postby Sometimewoodworker » Thu Feb 18, 2016 7:31 am
jamess1970 wrote:Sometimewoodworker, you're building a workshop I'd kill for! Is you crane setup going to be powered or just manual movement?
Hi James
It will be manuel movement and at the start manuel lift too as night now I have to be careful about cash flow. Also it's intended use is in moving sheets of wood products like MDF, OSB, and plywood then getting finished items onto a workshop dolly. It's being designed to lift up to 500kg. This means that a manuel system will easily be good enough.
Postby Sometimewoodworker » Wed Feb 24, 2016 9:52 pm
February 17 ~ 18
An extra been is needed
Postby Sometimewoodworker » Wed Feb 24, 2016 10:36 pm
February 18~19
A canary support
Maybe enough sockets:)
Starting on the gutters
Postby jamess1970 » Thu Feb 25, 2016 2:40 pm
Did they miss that beam on the drawing or did your engineer add it after a site visit? You can never have too many outlets in the workshop or kitchen.
jamess1970
Postby schuimpge » Thu Feb 25, 2016 2:42 pm
Will the canary support be encased? Or just leave it bare?
Looking good. Very curious how you'll get your workshop fitted.
(And you're a bit low on power-outlet's if you're not putting at least 4 outlets per point in... :D That's my experience from having 3 power-points with 2 outlets each on a 4 meter workbench, not even close to enough.... :mrgreen: )
Postby Sometimewoodworker » Thu Feb 25, 2016 3:13 pm
jamess1970 wrote:Did they miss that beam on the drawing or did your engineer add it after a site visit? You can never have too many outlets in the workshop or kitchen.
Which beam?
And I agree :D
Postby Sometimewoodworker » Thu Feb 25, 2016 3:14 pm
schuimpge wrote:Will the canary support be encased? Or just leave it bare?
I have double outlets every 1/2 metre. Enough?
