Workshop and house, Non Sa-At ½ way between KK & Udon
Re: Workshop and house, Non Sa-At ½ way between KK & Udon
Postby Sometimewoodworker » Fri Feb 05, 2016 8:58 pm
claynlr wrote:Looking good STWW! A few questions:
1. What dimension are your rafters spaced?
2. What did you use for the purlins that the roof steel will be attached to?
3. Was a steel sub fascia welded to your rafter tails before the decorative fascia is attached?
1) AFIR 1 metre
2) 2"x3"
3) I don't understand the question but this should give the answer
Postby eyecatcher » Fri Feb 05, 2016 9:51 pm
schuimpge wrote:Aren't you getting bored that everything is going by the book? lol
Looks great. Very curious to see the finished result.. As undoubtedly you will be as well.
Pretty sure he is happier as it is than to have to endure my build and stresses.
He does need to get some sunshine on those legs though, don't you think. maybe he is promoting snail white for 'er indoors :wink:
Postby Sometimewoodworker » Sat Feb 06, 2016 7:59 am
4th February
Postby Sometimewoodworker » Sat Feb 06, 2016 8:25 am
February 5th
Kitchen window
Postby Sometimewoodworker » Sat Feb 13, 2016 10:12 pm
February 6~
Cold
Kitchen windows
Bedroom windows
Postby Sometimewoodworker » Sat Feb 13, 2016 10:17 pm
February 8~
Not good
Better
Postby Sometimewoodworker » Sat Feb 13, 2016 10:23 pm
February 11~12
Postby Sometimewoodworker » Sat Feb 13, 2016 10:34 pm
February 11~12
Fire brigade water delivery
Water and gutter
Postby sirgunas » Sun Feb 14, 2016 11:53 am
Hi,
Will you be posting an estimated cost of your project?
I maybe starting a project of my own...
sirgunas
Postby Sometimewoodworker » Sun Feb 14, 2016 1:23 pm
sirgunas wrote:Hi,
Hi
Maybe introducing yourself and what you're thinking of building would be a good idea.
The place for that is under.
http://www.coolthaihouse.com/forum/viewforum.php?f=4
Postby jamess1970 » Tue Feb 16, 2016 12:38 pm
Sometimewoodworker, you've got a nice build going on. I especially like your concrete room you built. The only thing I see that I don't understand is, why are you letting the electrician but junction boxes with connections behind the wall. If something happens in the future you have no access to the box!
jamess1970
Postby Sometimewoodworker » Tue Feb 16, 2016 2:07 pm
jamess1970 wrote:Sometimewoodworker, you've got a nice build going on. I especially like your concrete room you built. The only thing I see that I don't understand is, why are you letting the electrician but junction boxes with connections behind the wall. If something happens in the future you have no access to the box!
The alternative would be surface mounted boxes, & I know which I prefer.
Postby Sometimewoodworker » Tue Feb 16, 2016 2:20 pm
February 12~14
Not a common sight here
Last edited by Sometimewoodworker on Tue Feb 16, 2016 2:28 pm, edited 1 time in total.
Postby Sometimewoodworker » Tue Feb 16, 2016 2:28 pm
February 15
The supports for the crane
Postby schuimpge » Tue Feb 16, 2016 4:37 pm
Looking good.. Not sure how the support for the crane at the door-side is done, but the other side looks to be a separate column made for it.
At the door-side, looks to be a metal plate that has been tied into the beam/superblock wall, but not very clear from the pictures.
Overall, the more I'm looking at your build, the more I start to plan and look around for getting some land..lol.
I have a nice house and a good amount of area to use as workshop, but seeing the workshop you are building, that's just awesome..
