Sources of wood, wood working tools and equipment
Anything to do with wood or woodworking for example, DIY woodworking, Construction techniques using wood, etc.
Re: Sources of wood, wood working tools and equipment
Postby Sometimewoodworker » Thu Oct 30, 2014 6:28 am
Roger Ramjet wrote:This is the one I had for years and how it should be set-up: http://www.chronos.ltd.uk/acatalog/info_2221.html
Thanks. I've got one of those. As Mike is giving you one your problem is fixed however if you need to get another then Woodcraft has them and ships overseas.
Postby Roger Ramjet » Thu Oct 30, 2014 7:00 am
Sometimewoodworker wrote:As Mike is giving you one your problem is fixed however if you need to get another then Woodcraft has them and ships overseas.
Okay, thanks, I'm not a great fan of blunt drill bits that have been used just a few times. I've always found when drilling metal, it pays to have some motor oil handy to dip the drill bits in at the start and to have a piece of wood under the metal so it doesn't strike concrete or dirt.
Postby Mike Judd » Thu Oct 30, 2014 10:16 am
First of many Swiss tools required
Just as a matter of interest, in one of my periods of semi retirement boredom, I took up wood carving and joined the Wood Carving Club of N.S.W. so here's my efforts before discovering the delights of Thailand which were a bit more Physical. Start at the bottom pictures for sequence order. keep forgetting to get it right. :wink: :wink:
Inside boxes with tray that sit on corner inserts that bind the mitre joints of the boxes together.
Second box same timber as it polishes up so smooth.
First jewellery box, Australian Cedar with Huron Pine carving.
My effort at a Nude, When carving the head there was a dead beetle in there so I had to put a cap on her. Jelutong wood stained.
Salad Spoon and Fork next in Huron pine, then Hand Mirror with platypus carving on handle, Austraian Cedar.
Wombat Australian cedar
Postby Mike Judd » Thu Oct 30, 2014 10:36 am
Here's a couple more.
She had nice big tits but daughter said too big ? so I whittled them down ,now she needs Silicone implants.But her Bums O.K.
Mitre joints on box/Lid and tray with Huron Pine inserts for strength.
Better view of the little Platypus, whole thing was split to get mirror inside.
Postby MGV12 » Thu Oct 30, 2014 10:54 am
Mike Judd wrote:Here's a couple more.
You do like to keep yourself busy don't you.
Impressive work but your daughter needs counseling on the tit aspect ... probably only available in the US where you can get counseling for anything and everything :lol:
Postby Mike Judd » Thu Oct 30, 2014 12:54 pm
Well there's no truer saying than " If you don't use it ,you lose it ! " And I haven't lost anything yet , except a bit of muscle, here and there. :( :( :(
Postby Sometimewoodworker » Sun Nov 30, 2014 10:37 am
jack9 wrote:
Sometimewoodworker wrote: TS55, OF1400, CT22, Rotex150, DTS400, ETS150/3, Domino, MFK700
hello woodworker
if you could kindly showcase some of your diy projects, it could really get the forum going.
for me as a noob, what i have is a pretty banged up maktec router. personally for myself is to get my woodworking skills up before comtemplating more expensive purchases.
is there a difference between working on local hardwood and temperate hardwood? i read something about length of the grain, and whether it is open or closed. for example in making a dovetail joint, are they more subject to tearout?
For your maktec router I recommend the thaicarpenter router table
Unless you want to build a simple one
Router table
Simple projects are tables specially if you buy the legs
Dining table
TV table
The only problem with the TV table is that then SWMBO has to get a TV for it (giving away the current one) and new windows and new curtains. :wink: :wink: :roll:
New TV
You can also make custom sized tables.
7 sided table, designed for the space
Postby jack9 » Sun Nov 30, 2014 5:57 pm
nice :)
do you have any advice on how to route really small pieces of wood?
i'm thinking the clamp will get in the way of the router
jack9
Postby Sometimewoodworker » Sun Nov 30, 2014 6:48 pm
nice :)
Don't :D
Seriously though, rout big pieces then cut them into smaller ones.
If you take a look at Tom Silver and how he makes door trim to fill in the closing rebate in an old house youwill get the idea.
Edit: the previously linked YouTube video has gone and I can't find a replacement. STWW
Postby schuimpge » Thu Nov 02, 2017 11:57 am
Very old thread, but another good source of tools (and prices) is waantong
Return to wood and woodworking
