Udon Thani Happy House
Re: Udon Thani Happy House
Postby pipoz » Sat Jun 21, 2014 7:16 pm
For those of you who may be interested in CPA Roof Tiles and who can read Thai, please find attached Home Mart Quotations for,
1. Prestige Horizon or Prestige CPAC Tile (Midnight Grey or Pewter Grey): For supply only of 2454 No main tiles plus accessories (216 m2 of actual roof area surface) it is TB 135,218 = TB 626 per m2.
2. Neustile Trend CPAC Tile (Black Steel or Grey Slate): For supply only of 2315 No main tiles plus accessories (216 m2 of actual roof area surface) it is TB 164,322 = TB 760 per m2.
UT Home Mart Quotations 13 June 2014.pdf
Roof Tile Quotations in Thai
(189.3 KiB) Downloaded 91 times
Postby pipoz » Thu Jun 26, 2014 1:02 am
Thanks Jomoblues
Postby pipoz » Sat Jun 28, 2014 6:44 pm
My Summary of Quotations-Cost for Windows and Doors, for either Aluminium or UPVC systems, from seven Suppliers.
Still not complete and will refine it further, once I get back to Thailand to have a look at some of the actual profiles and colours in the Showrooms
0 A00 Happy House Window Cost 2806 2014 Rev B.xls
Cost Summary for Windows & Doors
(60.5 KiB) Downloaded 136 times
Postby pipoz » Thu Jul 03, 2014 11:09 am
Jomo,
The boys came to inspect and measure up on Monday
Khun Agon 30 June 2014
Postby jomoblues » Fri Jul 04, 2014 3:12 am
That's good news. At least you've got your roof sorted.
Congrats. JoMo
jomoblues
Postby pipoz » Sat Jul 05, 2014 10:45 pm
Some preliminary Elevation Drawings, Front & Rear
A more typical Roof Framing Layout, although it looks like I will now end up going with a Top Hat Roof Frame system
DRAWING-540 Roof Framing Layout 30.pdf
Roof Framing Layout Drawing 540
(143.35 KiB) Downloaded 141 times
DRAWING-550 Front Elevation 30.pdf
Front Elevation Drawing 550
(234.78 KiB) Downloaded 119 times
DRAWING-555 Rear Elevation 30.pdf
Rear Elevation Drawing 555
(229.24 KiB) Downloaded 90 times
Postby pipoz » Sat Jul 12, 2014 12:37 pm
pipoz wrote:For those of you who may be interested in CPA Roof Tiles and who can read Thai, please find attached Home Mart Quotations for,
Roof Price Update
Have two reliable quotations in so far for the Roof Package.
The package will include Materials and Installation Labour and VAT for the following,
1.Fabricated Roof Framing Truss system (Two systems to choose from)
2.Additional Support Steel for large span areas
3.Reflective Foil Insulation Membrane under Roof Tile (237 m2)
4.CPAC Neustile Roof Tiles (216 m2)
5.Special CPAC Tile & Roof Vent (2 No)
6.Main Roof Thermal Insulation (96 m2) - CRB 32 Density x 50 mm on Wire Support system (because I will select a dark roof tile colour)
Excluding the VAT component, the average rate per m2 (for the roof area on slope) is
Materials: TB 1,631 (Quote 1) up to TB 1,871 (Quote 2)
Labour: TB 364 (Quote 1) up to TB 592 (Quote 2). I think Quote 1 is too low in his overall labour cost
If I include All components, i.e. Materials Labour and VAT the average rate per m2 (for the roof area on slope) is
Quote 1: TB 2,109 per m2
Quote 2: TB 2,463 per m2
Will post the spreadsheet, with detailed rates and costs, once I have signed one of them up.
Postby pipoz » Tue Jul 15, 2014 9:15 pm
Finally got the two Quotes translated from Thai to English and given some inclusions in one and exclusions in another, the revised numbers for supply of materials & labour, came out to be
Quote 1: TB 2,165 per m2 of sloping roof area
Quote 2: TB 2,342 per m2 of sloping roof area
Scope, specs & inclusions,
2.Three additional Support Steel Beams for larger spans
3.Reflective Foil Insulation Membrane under Roof Tile (237 m2) - Elephant Brand
4.CPAC Neustile Roof Tiles (216 m2) - Dark Grey or Slate colour
6. Dry Tec Roof system under Ridge & Hip tiles
7.Roof Thermal Insulation (121 m2) - CRB 32 Density x 50 mm on Wire Support system
8.VAT (7%) Included
9.Transport to Site - Included
10. Loading Tiles onto Roof - Included
If I were to opt for the CPAC Prestige Horizon Roof Tiles (Midnight Grey or Pewter Grey) instead of the Neustile, then the Rates would drop to TB 2,030 and 2,202 per m2 of sloping roof area, respectively - a saving of about TB 135 per m2.
Postby pipoz » Tue Jul 15, 2014 10:09 pm
The final two Neustile Roof Tile colours that I have selected and the roof Pitch looks close to min, about 30 Degrees.
Neustile Trend Grey Slate
Neustile Trend Black Steel
Postby pipoz » Wed Jul 16, 2014 7:10 pm
Final Roof Package Cost Spreadsheet and all agreed with the Roofing Contractor. Pay a 50% Deposit to him tomorrow and he is off and running. It should take 5-6 weeks to complete from now
Went for Option 1 - Quotation 1; Using the CPAC Neustile Roof Tiles (Refer the 3 Blue Columns - Figures/amounts in Purple & Blue are all confirmed and locked in and those is Red are pretty accurate estimates.
All equates to TB 2,328 per m2 for a sloping roof area of 215.9 m2
Hopes his helps someone
Many thanks to Jomo
CTH 0 A00 Happy House Roof Package Cost 1507 2014 Rev B.xls
(92.5 KiB) Downloaded 101 times
Postby pipoz » Sat Jul 19, 2014 4:16 pm
Some preliminary concept drawings of the Ceiling & Lighting layout and the three main External Elevations.
Spotted shading on the elevation drawings is just for Profile effect. Final facade colour, texture finish and stonework layout is yet to be decided. Will decide after I see what stone cladding materials (colour & finish) are available locally in Udon Thani, later this week.
Thinking at using Jota-shield in some external wall areas, mixed with stone cladding & some copping for the first 400 mm and also for the column areas
Drawing-600.pdf
Ceiling & Lighting Layout Drawing 600
(129.2 KiB) Downloaded 101 times
Drawing-550.pdf
(222.99 KiB) Downloaded 74 times
Drawing-555.pdf
(230.46 KiB) Downloaded 52 times
Drawing-560.pdf
West Elevation Drawing 560
(215.19 KiB) Downloaded 52 times
Postby pipoz » Sun Jul 20, 2014 6:03 pm
Just playing around with some ceiling and lighting layout options, if I introduce two bedrooms on the east side
Drawing-602.pdf
Option Lux 1 Ceiling & Lighting Layout
(130.48 KiB) Downloaded 56 times
Drawing-600.pdf
Basic Ceiling & Lighting Layout with Bedrooms
(134.04 KiB) Downloaded 51 times
Postby pipoz » Thu Jul 24, 2014 10:17 pm
Today, I thought I would pop into local CPAC and just check out the current Ready-mix prices.
In Udon Thani south side plant, delivered to site, they are,
24 Steng TB 1,960 per m3 in a five m3 Truck
28 Steng TB 1,990 per m3 in a five m3 Truck
30 Steng TB 2,010 per m3 in a five m3 Truck
Postby pipoz » Sun Aug 03, 2014 6:26 pm
Some stone wall and floor materials that I was looking at the other day.
Ranging from TB 2,800 to 3,300 per m2
Travertine Wooden
Travertine Navara
White Vanilla
Bella Flower
Postby pipoz » Sun Aug 03, 2014 6:37 pm
Some external wall stone cladding and paving tiles at Thaiwasadu
Rough Stone
Split Stone
Split Stone
Split Stone
Split Stone
Granito Tiles
Terracotta Look
