jazzman wrote:Make sure that the rubber waterstop strip is embedded half in the floor and half in the wall above it. This will provide a perfect waterproof joint between the floor and the walls; reason being is that two separate casts of concrete will never have a waterproof joint.
scudman wrote:
How does the rubber seal maintain it's shape when cement is poured on top of it from 1.5 meters height when you pour the walls of the pool?
Sounds as if you have built several pools - you must have a big gardenEnglish Tim wrote:I am always there at the pour
Well,first off, we don't use liquid chlorine. TCCA (chlorine speiically manufactured for pools) is sold in powder, granular or tablet form and contains essential Cyanuric Acid. The powder and granules are fast-reacting and are generally used for shock treatment, while the tablets are 'slow-release' for maintaining a regular chlorine level.scudman wrote:I am still mulling around in my mind whether to go salt water or the liquid chlorine route.
jazzman wrote: Well,first off, we don't use liquid chlorine. TCCA (chlorine speiically manufactured for pools) is sold in powder, granular or tablet form and contains essential Cyanuric Acid. The powder and granules are fast-reacting and are generally used for shock treatment, while the tablets are 'slow-release' for maintaining a regular chlorine level.
jazzman wrote: while an optimal balance should be found. and maintained between the draught from the balance tank and the main drain. The water level in the maindrain tops itself up from a float valve connected to the domestic water supply.
