Bi-folding doors and integrated blinds
Postby malcolminthemiddle » Thu Apr 02, 2009 3:34 pm
Has any one come across bi-folding doors and integrated blinds in Thailand either locally supplied or imported. Many thanks.
malcolminthemiddle
Re: Bi-folding doors and integrated blinds
Postby MarkOsborne » Tue Oct 05, 2010 1:37 pm
<edit: post removed .. no advertising or self-promotion allowed ... please see forum rules. MGV12 .. moderator>
MarkOsborne
Postby pipoz » Thu Oct 11, 2012 12:40 pm
Hi,
In my current planned house design, I have a number of external Bi Fold timber/glass doors. About 24 number, door leafs in total. Have added some indicative pictures to give an idea
Most are in standard 4 meter wide openings, with 4 No x 1 meter wide leaf doors, where two will fold back to each side. One detail is a pillar free corner unit for about 8 doors and structurally I can make it work.
I am looking for a quality joinery/carpentry Company who only has to make the timber frames, from a quality hardwood, and route them for the hinges and door hardware. The overall size of each timber door frame is 2200 mm high x 1000 mm wide and the nominal timber section base & style) size is between 150 – 180mm x 50mm.
I need a good local hardwood. Not worried about the door hardware, as I can source a quality type from where I am.
If anyone has come across a Company that specializes in one of carpentry/joinery works, I would appreciate some leads and or contact details. Likewise if anyone has some suggestions on the type of local hardwood available, please let me know.
Regards
Phil
Postby pattayapope » Thu Oct 11, 2012 12:56 pm
A friend had some built and the guy did a beautifull job and still look good 3 years down the road, I will email him and ask for more details but from what I remember they were very very expensive. From what you say you need for your place you will need a big budget to get quailty doors made from good seasoned hardwood otherwise you will have a lot of problems with warping ect. From what I remember it was over 100,000 for one four panel door!
Postby pipoz » Thu Oct 11, 2012 1:23 pm
pattayapope wrote:A friend had some built and the guy did a beautifull job and still look good 3 years down the road, I will email him and ask for more details but from what I remember they were very very expensive. From what you say you need for your place you will need a big budget to get quailty doors made from good seasoned hardwood otherwise you will have a lot of problems with warping ect. From what I remember it was over 100,000 for one four panel door!
Thanks, and "Its only money and I am only on this planet for so long", so may as well enjoy it.
Phil
Postby pattayapope » Thu Oct 11, 2012 3:03 pm
After I posted the message I googled and there is a company in Chaing Mai that makes them, easy to find if you google and you should be able to get a quote easy enough so you can adjust your budget as necessary[*] :D
Postby pipoz » Thu Oct 11, 2012 3:13 pm
Hi and thanks. Presume its Aus Eco
