wood or conwood facade
Postby Sunpax » Wed Nov 16, 2011 6:11 am
is it possible to put planks on the externe wall , direct on the blocks without the need to make a render first ?
what about all the little "animals" between the wall and the planks ?
How to seal the planks together ?
Until now doesn't find any informations on the net !
Thancks a lot
Sunpax
Re: wood or conwood facade
Postby otis-a » Wed Nov 16, 2011 8:29 am
generally - yes
what performance is achieved is another issue.
What type wall- standard breeze blocks? Doubtful for long term service. The std. Breeze block is very weak, go look at an naked constructed pwall. U likely will see several holes develop over time. Also when std breeze blocks are unloaded look at how easily they fall apart. It is the render and interally placed steels rods that develop the strength. This my observation.
The stronger blocks i havent any experience.
Perhaps consider framing to your cement columns and beams. But this begs a second issue of sun's UV action on plastic's. Possible the conwood coating/ painting- is sufficient but have seen examples where it has notwithstood sun.
Postby splitlid » Wed Nov 16, 2011 5:24 pm
no, it will look shite, you need to make sure the wall you are placing it on is flat and level.
i can guarantee that your wall is not,
but hey, just do it.
splitlid
Postby otis-a » Thu Nov 17, 2011 3:24 pm
s'lid wrote:
'' » Wed Nov 16, 2011 5:24 pm no, it will look shite,''
as in?
The light brown or the dark? Maybe yellow or green?
Or the flat pasty?, perhaps lumpy? Or the dayold?
Hi s'lid,
is it possible to improve the description?
Postby splitlid » Fri Nov 18, 2011 1:05 am
pooh's pooh at the end of the day, regardless of colour or consistancy.
the surface needs to be flat, either by framing it with pretreated timber or a fabricated steel frame, the timber or fibre board is then glued/screwed/nailed to the frame.
of course window frames etc have all been installed with this in mind 8)
splitlid
Postby runker » Fri Nov 18, 2011 2:30 am
Why not use Shera planks for your siding. Not sure how you would attach it to the walls, I guess you could attach steel studs every 24 inches and then attach the planks to them. You may even have enough space between the studs to put insulation.
runker
Postby Sunpax » Fri Nov 18, 2011 7:54 am
I will love to put tek wood on ! but i doubt that i can buy 120 m2 tek for only 120 000 bahts (my budget )
my question was if i don't render ,whats about all animals between the walls and wood or shera (conwood)
can i seal the wood between or the shera between the plank ? with what ? ciment ? silicone ? gyps ?
if the planks are not seal together what's about the rain ?
for what i think need to be render before ! i am not sure...i just begin to look for informations
thanck you :)
Sunpax
