Staircase railing design
For general discussion of:
1.) Project management or other professionals used during the project.
2.) Anything related to house design tools and applications. This would be an area to share and get feedback on your ideas for a house plan.
3.) Architectural styles used within Thailand.
Postby AJBangkok » Sat Nov 26, 2016 10:40 pm
I wonder if anyone could point me in the direction on how to get a staircase railing designed and fabricated similar to one in the pics below. I think it could be done out of sheet metal using a computer driven laser cutting machine but I'm not sure. I would want to use it on a curved staircase not a spiral staircase but I would also consider using it on a second staircase in the house which is L shaped.
AJBangkok
Re: Staircase railing design
Postby schuimpge » Mon Nov 28, 2016 10:42 am
Hello AJ,
You'd need a company that has a plasma cnc.
Google for Thailand CNC-machine and ask suppliers for a customer of theirs that have such machine.
Might be the easiest way to find it...
Here's an example: https://www.youtube.com/watch?v=XrCsbAWZYYc
And another one: http://www.extracnc.com
(I don't have any connection to the above companies/persons, I just googled "plasma cnc thailand" and took the first results with Thai language in their header)...
Good luck..
Postby AJBangkok » Mon Apr 10, 2017 7:44 pm
Just an update I found a company to make the railing and so far I'm impressed with what they can do.
They are starting to install it now so hopefully it will look great when it's finally done. The railing is a bit pricey but that's due to fabricating it in stainless steel. If I did it in steel it would be less than half the cost.
AJBangkok
Postby pipoz » Mon Apr 17, 2017 10:42 am
Nice staircase design
Return to House Design, Architecture & Project Management
