Stone, Metal & Glass
For general discussion of:
1.) Project management or other professionals used during the project.
2.) Anything related to house design tools and applications. This would be an area to share and get feedback on your ideas for a house plan.
3.) Architectural styles used within Thailand.
Re: Stone, Metal & Glass
Postby andymac » Tue Dec 13, 2016 7:50 pm
Here's a quick update showing the construction of the ground beams that will support the stone faced walls.
andymac
Postby andymac » Tue Dec 13, 2016 8:00 pm
Finally the area is backfilled and all the heavy work is buried out of sight.
andymac
Postby andymac » Sat Dec 31, 2016 3:57 pm
Here's the last few updates for 2016 and looking forward to 2017.
Some photos showing the fabrication of the support for the floor beams.
The beam on the right will span 9 meters without any central ground support.
We will have three cantilevered beams from the second beam to provide support.
Next will be the floor panels delivered and then the structure starts to take shape and look more like a building.
Wishing all CTH readers and contributors a very Happy New Year for 2017....
andymac
Postby pipoz » Sun Jan 01, 2017 5:03 pm
andymac wrote:
The ground looks soft
What is is a mixture of loamy soil and some part clay
Nice big foot print to the pad footing
Postby andymac » Tue Jan 31, 2017 11:39 am
Happy Lunar New Year - Welcome to the year of the Rooster!
Some photo updates. preformed floor panels installed
View from rear
Cut out for washroom and shower area
Concrete pour 150mm screed
Rear view, looks huge again
Front view. cut outs at sides for roof drainage
General view showing relationship to pond
andymac
Postby andymac » Thu Feb 09, 2017 9:53 pm
We now have posts...
Latest photo updates
Top beams next on the list.
andymac
Postby andymac » Sat Feb 18, 2017 9:10 am
Hi All
Back in Thailand for a few days to oversee the construction of the top ring beams. We will have ten concrete beams of various specs and two steel I beams, they'e on order and installation will have to wait for my next trip as we have some complicated details that need careful attention, to make it all look simple and clean.
Cross beams constructed first
On the right you can see the pile of rocks for the stonemason
North facing rear facade
Rear beam, completed garage in background
View in other direction, pond in background and deck for yet to be started Teak Pavilion
Concrete arrives right on schedule
Good progress but still a long way to go
andymac
Postby BKKBILL » Sat Feb 18, 2017 5:25 pm
Looks good Andy keep up the good work.
Postby andymac » Fri Mar 17, 2017 11:02 pm
Some more beam updates
I'll be back in CM next week to move things along - making payments usually works.
Preparing the rebar for the double side beams
All the bamboo is cut from the land, fortunately it grows back pretty quickly
A good shot from the drone
Vibrating the concrete
Hiring a crane to help pour the concrete really speeded things up
Front view
Rear view
Next we will start on the stone faced side walls, going with cinder block on the outside wall and Q-con on the inner wall.
Stay tuned.
andymac
Postby andymac » Tue Mar 28, 2017 7:42 pm
Finally we have some walls going up.
Just returned from a very productive trip to Chiang Mai. We've made a start on the exterior cinder block walls, these will be faced in stone, same as we did with the garage. You can see the lip on the ground beam, this is to support the stone work and will be slightly below the finished ground level. The rear wall, not started yet, will be a double skin Q-con block rendered, painted white and with three long strip windows.
andymac
Postby Roger Ramjet » Wed Mar 29, 2017 12:26 am
andymac wrote:Finally we have some walls going up.
Looks pretty solid to me Andy. Plenty of rebar in those beams and columns too. No problem with an earthquake on those walls.
Postby Klondyke » Sat Apr 01, 2017 7:40 pm
Will the walls make your house "Cool Thai House"?
Postby andymac » Fri May 05, 2017 10:49 pm
I certainly hope it w'll be cool in both senses of the word.
We did a trial run on the garage studio build, Q-con block faced with stone. Pleasantly cool to the touch on the inside face when the sun is heating up the stone outside. The Stone Pavilion has the addition of a 70cm cavity that should help further in keeping the temperature down inside.
andymac
Postby schuimpge » Fri May 05, 2017 10:53 pm
70 Centimeter?!
Or 70 Millimeter?!
Postby andymac » Fri May 05, 2017 11:02 pm
Applying a coat of Sika water proofing before the stone facing
Exterior block walls complete,
Q-Con block delivered, dropped off at main entrance for some reason.
Rear Q-con cavity wall completed, 7.5 +5 + 7.5
Stone work next
andymac
Return to House Design, Architecture & Project Management
