Rain gutter
Rain gutter
Postby idcpeter » Mon Apr 13, 2015 11:13 am
I need some information about rain gutters. Which products are good from which company?
Best
Peter
idcpeter
Re: Rain gutter
Postby iammike » Tue Apr 14, 2015 10:33 am
Here is one http://www.windsor.co.th/rain_gutter_productsEN.html
For sale at your local HomeMart store
iammike
Re: Rain gutter
Postby idcpeter » Tue Apr 14, 2015 11:06 am
Thanks, but they have no rubber seal between the joints! How to seal it?
idcpeter
Rain gutter
Postby iammike » Tue Apr 14, 2015 11:11 am
If looking at the installation brochure http://www.windsor.co.th/download/RG_Installation.pdf
They have a joiner which slides 5cm on each side over the other piece (look at picture 6)
Ps; There is a picture of the joiner on the homepage (text says: joiner with smooth linkage)
iammike
Re: Rain gutter
Postby idcpeter » Wed Apr 15, 2015 10:05 am
Thanks, but my friend have the windsor rain gutter and always on the joint there are leaking! He try to seal it with silicon, but just leaking!
There is no other product at the market?
idcpeter
Re: Rain gutter
Postby iammike » Wed Apr 15, 2015 10:31 am
No idea really but an alternative is those trucks that drive by and will install that cheap (I don't know the English name for it, but in Thai it's call Sang kha See) rain gutter.
iammike
Re: Rain gutter
Postby Sometimewoodworker » Wed Apr 15, 2015 10:36 am
iammike wrote:No idea really but an alternative is those trucks that drive by and will install that cheap (I don't know the English name for it, but in Thai it's call Sang kha See) rain gutter.
You can buy the same profile gutter in galvanised steel from most of the usual places, TW,GH,& DH the price is about 1/4 or less of the price the trucks charge
Gutter
Re: Rain gutter
Postby olavhome » Sun Apr 26, 2015 2:14 pm
The WInsor gutter joints: How about to glue them with same glue that is used for blue plastic pipes ? Would not that prevent leaking?
olavhome
Re: Rain gutter
Postby thailazer » Sun Apr 26, 2015 5:36 pm
Make sure you can easily remove your downspouts. In our four years at the house, the starlings made those downspouts the highest maintenance item on the whole property. At least two cleanings a year. Even in rainy season, they would make a nest in them. Fortunately, it was an easy job for us, but it could have been a real pain if they didn't come down easily.
Re: Rain gutter
Postby olavhome » Sun Apr 26, 2015 9:52 pm
To try to avoid birds nests in the downpours I did make a small "ball" of barbed wire and put over the opening. Have not seen any signs of nests after that :-)
But it is a good habit checking the gutters annually for leaves etc, specially if big trees in the area .
olavhome
