Grass lawn on top of flat concrete roof
Postby arranp » Mon Apr 28, 2014 8:03 pm
Hello,
Anyone have knowledge and can give pointers to companies that lay a grass lawn ontop of a glat concrete roof, the way to do, whats involved etc.
building on a sloping land, have the garage at ground level and ontop of the garage to have a 17m x 8m lawn for use by the kids to play on etc.
Thanks in advance for advice.
Regards
Arran.
arranp
Re: Grass lawn on top of flat concrete roof
Postby Sometimewoodworker » Tue Apr 29, 2014 6:10 am
arranp wrote:Hello,
Regards
Arran.
You would be better advised to put sweet potatoes on the roof as they provide better heat reduction, are easier to maintain, and food. The study I saw said the sunlight usage was 40% higher Tha grass.
http://www.japantimes.co.jp/news/2006/09/07/national/ntt-firms-say-sweet-potatoes-best-to-fight-heat/#.U17g9P8aySM
Postby cooked » Sun May 04, 2014 3:25 pm
1. Leaking
2. Not leaking yet
I had many hours of well paid fun fixing green rooves. Either they leak or the drainage doesn't function.
cooked
Postby Sometimewoodworker » Sun May 04, 2014 3:32 pm
cooked wrote:1. Leaking
2. Not leaking yet
The sweet potatoes were hydroponic so didn't have any effect in the "1. Leaking
2. Not leaking yet"situation.
Postby Ians » Wed May 07, 2014 8:32 pm
If you intend turning your roof into a garden / lawn you will need to pay very careful attention to the waterproofing of the concrete - you will need to do a bit of research into membrane / sealing etc. as you would not want to bet your most precious appendages that it won't leak - maybe not this week / month / year but at some time in the future it will leak - water has a habit of finding the most minute area to start leaking - either via gravity or capillary. Being Thailand a couple of sheets of plastic thrown under the garden / lawn would be the norm for water-proofing - that's if they even bothered being so sophisticated.
Postby schuimpge » Wed May 07, 2014 10:19 pm
Better install a bunch of solar panels over the roof.
No worries about concrete heating up, no maintenance and free electric to boot.
Postby Andyfteeze » Sun Sep 07, 2014 9:48 am
Are the foundations strong enough to carry the extra weight? 1 litre of water equals 1 kg. soil is heavier than water. Be careful with the weight. If its exposed to the elements and you get a down pour, the weight could DOUBlE !!
Its a good idea but really should be factored in when building, not an after thought .
