Roofing costs (frame/truss and tiles/steel)
Postby wazza » Mon Nov 12, 2012 10:35 am
I am doing some research prior to doing a new build in southern thailand.
I have seen roofing cost details posted around the web and am having trouble finding it again, so thought I would start a new topic and see if we could pool this information together.
I have talked with bluescope steel regarding using there zincalume frame with colorbond steel roof and this is what I have recieved, I am still awaiting details on glued insulation on the colorbond steel
Roof truss
Roof truss material = Sq.m. x 700 = 126,000 Baht (Include transportation)
Installation cost of Truss = Sq.m. x 200 = 36,000 Baht
Metal sheet, Colorbond
Roof colorbond material = Sq.m. x 500 = 90,000 Baht (Include transportation)
Installation cost of Metal Sheet = Sq.m. x 100 = 18,000 Baht
I have also copied in this post by pipoz and hope others would post any prices they have come across for different types of roofing and roof frames.
Re: metal roofing and reflective foil
by pipoz » Fri Oct 05, 2012 5:54 pm
Metal roofing (Lysaght and Stratco) and associated insulation systems, in the Australian outback for many years, vey successfully, (where tempratures are much higher than Thailand), and they work. Both Lysaght and Stratcohave good web page for anyone wishing to look
Recently I have been looking at the likely costs of a metal roofing system vs the more traditional concrete rood tile systems, for my house in Thailand, For what I have been able to work out.
The Total Cost per m2 for a Metal Frame and Metal Roof Sheet system, seems to be in the order of 500 - 600 Thai Baht Per M2
The Total Cost per m2 for a Metal Frame with Concrete Roof tile system seems to be in the order of
C Pac Monier Prestige: 1200 - 1300 Thai Baht Per M2, based on the sloping roof area.
Mahaphant Shingle Style: 850 - 950 Thai Baht Per M2, based on the sloping roof area
AYARA Cerafino Style: 1500 - 1600 Thai Baht Per M2, based on the sloping roof area
Has anyone else done any recent comparisons or analysis of what their roofing systems have cost them in TB per m2
Phil
wazza
Re: Roofing costs (frame/truss and tiles/steel)
Postby wazza » Mon Nov 12, 2012 10:40 am
Re: Neustile Roof Tiles
by pipoz » Fri Nov 09, 2012 12:41 am
Hi priced some roof tiles last week in Udon Thani
Pics 1, 2 & 3: CPAC Monier PRESTIGE HORIZON & ZENITH range TB 34 per piece = 34 x 11 = TB 374 per m2 (supply only, delivered to site)
Pics 4 & 5: CPAC Monier CONTRAZZ & ZEASON range TB 19 per piece = 19 x 11 = TB 209 per m2 (supply only, delivered to site)
wazza
Postby wazza » Mon Nov 12, 2012 10:41 am
by jazzman » Fri Nov 09, 2012 12:09 pm
CPAC NEWSTILE™ quoted this week (Wednesday 7 November 2012) in Nam Pong, Khon Kaen province: ฿45.00 each including delivery. 11 pcs per m2.
Large independent builders' merchant.
wazza
Postby pipoz » Mon Nov 12, 2012 11:34 am
Hi and there is also this latest one for the supply of soem CPAC roof tiles that I priced last week in Udon Thani
No installation or framing costs are ncluded in the above rates. I will get some roof framing costs for these tile types when I am back there next month
Postby Sometimewoodworker » Mon Nov 12, 2012 12:30 pm
wazza wrote:I am doing some research prior to doing a new build in southern thailand.
You need to specify the type of Colorbond as there are several different profiles, fixing systems bad thickness's
In the "sunshade" thred the colorbond we used was = Sq.m. x 300 if we had had their insulation it would have been 50 Bhat Sq.m.
Postby fredlk » Mon Nov 12, 2012 1:35 pm
wazza wrote:Roof colorbond material = Sq.m. x 500 = 90,000 Baht (Include transportation)
90,000 Baht for 500 square metres of 'Colorbond' makes it 180 Baht per square metre. As I wrote elsewhere it must be a different Colorbond because mine was almost twice as expensive.
Postby Sometimewoodworker » Mon Nov 12, 2012 2:20 pm
You are spot on there Fred. At 180 Baht per square metre it isn't Colorbond. I was thinking he ment 500baht per square meter, which would make it much more expensive than mine but possibly a correct price.
Postby wazza » Mon Nov 12, 2012 4:17 pm
You are correct sometime woodworker, I had removed the 180m from the equation and the colorbond was quoted at 500bt per square metre, this quote came from bluescope itself rather than a roof builder
wazza
Postby fredlk » Mon Nov 12, 2012 4:19 pm
Postby pipoz » Mon Nov 12, 2012 6:20 pm
When I looked at a metal roof frame and metal roof sheet system (can't remmeber the roof sheet profile), I came up with a cost of roughly between TB 500 - 600 per m2 (for the actual sloping roof area), for a typical house layout, for the all up Supply and Installation of the roof frame and roof cladding material. Maybe I was light on?
Postby pipoz » Mon Nov 12, 2012 6:28 pm
wazza wrote:You are correct sometime woodworker, I had removed the 180m from the equation and the colorbond was quoted at 500bt per square metre, this quote came from bluescope itself rather than a roof builder
Wazza,
If I look at your post you have 700 + 200 = TB 900 for ther Supply and Installation of the Roof Framing and then you have another 500 + 100 = TB 600 for the supply and installation of the roof metal sheeting, which suggests to me, TB 900 + 600 = TB 1,500 for the supply and installation of the whole Metal Roofing System (frame & sheet) - with or without insulation?
Am I reading it correct, because if I am, it would seem to be to very expensive at TB 1,500 for a metal frame and metal sheet roof system, compared to that of a Monier CPAC Roof Tile system?
I can buy Monier CPAC tiles for between TB 209 (Zenith) per m2 and TB 374 (Pretige Horizon) per m2 (granted, just for the Tiles only)?
Postby Sometimewoodworker » Tue Nov 13, 2012 4:43 am
Which of the colorbond,"LYSAGHT KLIP-LOK®, LYSAGHT TRIMDEK®, LYSAGHT ULTIMA HI-RIB® profiles" did you select. Also which thickness? There are three.
Postby Sometimewoodworker » Tue Nov 13, 2012 5:09 am
wazza There is on point on that quote, and just for your information, at 300Baht Sq.m. for labour you have a very expensive deal.
If you can be sure you will get a perfect install then it may be worth the extra.
I am lucky that I have a very reliable worker, who is mainly a welder, who would even at ฿500+ a day with a crew be able to put on the roof for less than a third of BlueScopeSteel's price.
One further point I was quoted ฿50 Sq.m. for insulation by BlueScopeSteel. As I remember it was the same price for any profile.
Postby wazza » Tue Nov 13, 2012 5:54 am
I have only been contacting via bluescopes webpage and we had not discussed profile or or thickness or the clip method, I was more trying to get a feel for prices so I can compare with other roofing types.
Note, this is to be a beachfront build and I am concerned about rust and steel, so that is the reason for looking at zincalume trusses. The reasoning behind colourbond (with insulation) is that there are no horizontal joins so less places for storm driven rain to get into roof.
But I also want to compare prices against other materials as do not want to spend a fortune on what will be a holiday house. (my primary home being in Phuket)
wazza
Postby fredlk » Tue Nov 13, 2012 6:36 am
wazza wrote:Note, this is to be a beachfront build and I am concerned about rust and steel, so that is the reason for looking at zincalume trusses. The reasoning behind colourbond (with insulation) is that there are no horizontal joins so less places for storm driven rain to get into roof.
Just so that you are aware, Clean COLORBOND® is guaranteed for 30 years with a few exceptions, one being that it be situated further than 5 kilometres from the sea.
