Postby Sometimewoodworker » Fri Jan 15, 2016 4:07 pm
14th January part 1
What do you do when your rebar is about 4 metres high
Power outlet
Ready for concrete
Postby Sometimewoodworker » Fri Jan 15, 2016 5:15 pm
pipoz wrote:Nice I Beams
Can I ask what size are they and what weight per linear meter? i. UB 500 x ......x ......
Information given is H-350*175*7*11 and 49.6kg metre
So I think it is 35cm x 17.5cm and the 7 and 11 are the thicknesses
Postby pipoz » Sat Jan 16, 2016 3:58 pm
Thanks and I like those H Beams, need to get a couple for myself.
Just curious as to how you intend to use the H Beams in your workshop?
What span are you planning to use them over, 6 or 7 or possibly 8 m span? between columns?
I gather that you will support them at the ends on two columns and that you intend to run a motorized crane along the bottom flange of the beam? Is that correct or close to it?
I also suspect that you do not intend to build on top of the beam or to introduce any other point loading on the top of the beam?
Postby Sometimewoodworker » Sat Jan 16, 2016 6:24 pm
The original plan by my architect was to have the crane running on top of the beams
However I felt that since the loading is unlikely to be great I felt that the kind under would be good enough.
Postby eyecatcher » Sat Jan 16, 2016 6:42 pm
Those sizes are interesting in that I suspect they are rounded up or there is more than one "universal" standard.
The standard for this beam is actually 356x171 x45 or51kg depending on whether the web thickness is 7mm or 7.4mm (to be awfullly pedantic :wink: )
Were you asked for a maximum loading; because despite its size if its an unsupported beam spanning what? 7/8m the maximum load may surprise you it could well be less than 2.5ton.
as an aside; the beams they use in Global house in C.M, to carry all their steel stock are a much smaller section but span a relatively short distance and they have a loading limit of 3 ton
Cost wise, steel is more expensive here than the Uk, when i was costing my job as a steel structure it was heading around 60k baht/ton whereas readymix concrete is about 1000bt per ton. with labour so cheap, this is why you don't see many steel structures.
ok, so I see its two major beams, carrying a traveller beam...
eyecatcher
Postby Sometimewoodworker » Sun Jan 17, 2016 6:50 am
When I was getting the pictures from Facebook I missed about 10
So there are three more. And if the loading is more than about 500kg then it is within spec. As I intend it for moving wood and woodworking machines, none of the machines exceed 200kg to the best of my knowledge
Postby pipoz » Sun Jan 17, 2016 10:49 am
Ok understand.
So with your crane running along the bottom flange of the two main beams, you are not sitting those beams on a column Corbel? So how are you hanging or supporting/fixing the two main beams?
Column Corbel
Postby Sometimewoodworker » Sun Jan 17, 2016 12:21 pm
pipoz wrote:Ok understand.
Hanging off the roof steel AFIK
Postby Sometimewoodworker » Mon Jan 18, 2016 9:27 am
Really 14th January (part 1 was the 13th) concrete pour and some more rebar work
Good driving
Stairs that are easy for older people
Part of the top will be steel and part concrete 1
Part of the top will be steel and part concrete 2
Postby Sometimewoodworker » Mon Jan 18, 2016 9:42 am
15th January
The side and riser shuttering comes off
Another mistake is found, thank goodness I'm not paying per day or buying material, and it's a big time waste but not such a big material waste
Front stairs
Front stairs
Kitchen stairs
Kitchen stairs
The steel that should be used in the trusses arrived from Udon today. The steel group is not happy as they have a per job payment.
Postby Sometimewoodworker » Mon Jan 18, 2016 9:59 am
16th January (1)
Correct truss steel, spacers, beam security room shutting, etc.
Thai people do use umbrella hats!
I guess a small bit will be added
Good welding
Nui had not much problem going up, but down was a different matter. :wink:
Looks safe enough!
Postby Sometimewoodworker » Mon Jan 18, 2016 4:42 pm
16th January (2)
Continued
Going up was OK
You can just see our nearest neighbours
Coming down was not so easy but SWMBO made it
Postby Sometimewoodworker » Mon Jan 18, 2016 4:47 pm
17th January
Not much to show. The steel group was the only one working and they were rebuilding the trusses
So so welds
Postby pipoz » Mon Jan 18, 2016 5:10 pm
Sometimewoodworker wrote:17th January
He might have been better off if he used a few steel side plates at the main connections between the diagonal truss members and the bottom cord member. Then he could have got more weld length on it. Or maybe tried something like this
Truss Connection Ideas
Postby pipoz » Mon Jan 18, 2016 5:25 pm
Hi
Whats the idea/purpose of your RC wall structure
STWW - 01
