Postby Sometimewoodworker » Sun Dec 27, 2015 9:03 pm
24th November
The final part of the funeral ceremony is concurrent with the concrete pour
Places for the 7 monks
7 monks
7 monks
Offerings for the monks
Postby Sometimewoodworker » Sun Dec 27, 2015 9:14 pm
24th November part 2
The general idea is to have floors that are flat so they can be tiled using thinset rather than the usual Thai style of 10cm of concrete under the tiles. Only time will tell if the idea actually worked.
The helicopter goes into action
Christmas Day is a big monk day so there's no work done
Postby Sometimewoodworker » Sun Dec 27, 2015 9:40 pm
26th of November
My first sight of the work. Hummm they are working fast because the concrete has been ordered for the 28th and they have to get the framework ready.
Now I'm watching what's going on and notice this
Hummm
A closer view
Now I'm no expert but it looks as if there may not be enough spacers. So I ask SWMBO to translate and ask the leader of the group what the spacing of the spacers should be. The answer comes back that it should me at 1 metre intervals on alternating sides, not as we saw. So we thank him for the information and later call our contact, Khun Ruang his boss who calls him and tells him that he has to redo the shuttering with the correct spacers. I'm not making their day :?
One very small worker
Placing stirrups
To come: thicker concrete is not better it's just thicker, and miss communications make more work, also 3cm is not 6cm
Postby Sometimewoodworker » Fri Jan 01, 2016 8:24 am
Whoops I've just noticed I was writing November when it should have read December
27th December (the next day) they are working frantically to get ready for the trucks coming in tomorrow, so I'm staying well back.
Postby Sometimewoodworker » Fri Jan 01, 2016 1:03 pm
28th December
The columns are mostly ready to be poured.
Another crane
Working late into the night
There was about 1/2 a cubic metre of concrete left
The remaining concrete gets a home
Postby Sometimewoodworker » Fri Jan 01, 2016 1:33 pm
29th December
Problems and solutions
First more concrete is not better, the depth of the trough that the linear drain should fit into should be 6cm and it is about 2.5
Too shallow
The answer will be to dig out about 3cm in a square around the outlet.
Second problem, when we arrived back from Udon Thani the workers were about to leave for the new year holidays having "wrapped" the columns
I was neither impressed nor happy so decreed that every column had to be re wrapped and had to supply the plastic and tape for the wrapping.
Helping
How to show that the post had been properly finished. I had no idea when I bought this tape at auction about 35 years ago that it would have such a long life and be so useful.
Postby Sometimewoodworker » Fri Jan 01, 2016 1:42 pm
30th December
No work on the site, just adding water to the posts to ensure a proper cure
Postby Sometimewoodworker » Mon Jan 04, 2016 8:04 pm
4th January
The builders are coming back tomorrow and the roof metal team will be starting then.
So we have a supplementary temporary electricity supply
30(100)A supply
I was thinking that a vented roof ridge would be a good idea however SWMBO pointed out that it would be a disaster at this time of year and the reason is.
It isn't the house burning, that's just perspective, it's sugar cane.
Postby Sometimewoodworker » Thu Jan 14, 2016 10:01 am
I'm a week behind as it's a bit busy at work
7th January
Steel for the roof has arrived
Quality markings
And we have steel for the roof trusses
Truss sections
They are getting the stairs ready
Stairs
Stairs
And the workshop crane I beams (I think)
Postby pipoz » Thu Jan 14, 2016 8:06 pm
Nice I Beams
Can I ask what size are they and what weight per linear meter? i. UB 500 x ......x ......
Postby andymac » Thu Jan 14, 2016 9:10 pm
Hi SWW
Same question here as Pipoz, great looking beams. I tried and failed to get what I wanted as far as I beams concerned, I think it was a cost thing. I had to improvise.
Your project's progressing great.
andymac
Postby Sometimewoodworker » Fri Jan 15, 2016 2:25 pm
pipoz wrote:Nice I Beams
I've asked SWMBO to ask our builder/architect next time he is here
Back to the build
9th January
The first truss starts
Plates on top of the beams for ring beam hight
Front of house posts
Continuing with steps
To be continued
Postby Sometimewoodworker » Fri Jan 15, 2016 3:38 pm
9th January continued
Mistake number 2 or 3
It isn't a big problem, what happens if you don't measure twice and cut once
Measure once cut twice
More stairs rebar
Postby Sometimewoodworker » Fri Jan 15, 2016 3:54 pm
10th January
Stairs, top beam support, truss, reinforcing for 1 room, filling missing concrete in post.
10cm rise on steps for old people
Filling up the post
Fill weld on base of truss with tacks on other sections
Not enough steel to continue
Postby Sometimewoodworker » Fri Jan 15, 2016 3:58 pm
andymac wrote:Hi SWW
Thanks, yes it does look that way from here in Japan.
The speed of the project increase is in inverse proportion to the drop in my available money :? :(
I just hope the first finishes before the second.
