Postby Sometimewoodworker » Mon Mar 14, 2016 10:23 am
March 13th continued
Roughin render
Render top coat
Why use nails when there is a staple gun? Any suggestions
Render mixing machine with helper
More PU , this time for sound reduction
Concrete delivery, note the safety foot wear :)
Postby Sometimewoodworker » Mon Mar 14, 2016 8:57 pm
March 14th
Postby jamess1970 » Tue Mar 15, 2016 3:36 am
SSW, looking good. You lowered tour crane beam for light clearance or was there another reason?
jamess1970
Postby Sometimewoodworker » Tue Mar 15, 2016 6:43 am
jamess1970 wrote:SSW, looking good. You lowered tour crane beam for light clearance or was there another reason?
The crane is as high as it can be. It is an under slung design and there are 4 support points that hold the runway beams, the 2 in the centre come off the trusses but the ends are suspended from H beams under the roof steel. This means that the truss support points are the hight of the H beam lower than the trusses themselves. You then have the end trucks and the bridge girder is suspended from that.
It is a custom design with the stresses and loads calculated by our architect and his structural engineer. Total cost is about 1/5 of a quote we had from a crane company :roll: it cost less than they wanted for labour and shipping only.
Postby Sometimewoodworker » Wed Mar 16, 2016 8:55 am
March 15th
Last day for PU foam
Alternative use for the crane
Parking area and ramp final
Postby schuimpge » Wed Mar 16, 2016 11:44 am
I bet it's a lot cooler already inside the house?!
Looking good. Very curious for the coming weeks when detailed work starts to go in.
Postby Sometimewoodworker » Wed Mar 16, 2016 12:06 pm
schuimpge wrote:I bet it's a lot cooler already inside the house?!
That won't be in the coming weeks :( as there is a dead stop at the end of the month when we have to go back to the land of the rising yen :)
Postby pipoz » Wed Mar 16, 2016 12:15 pm
It looks like you are full steam ahead and trying to finish before you leave and the end of March
Postby Sometimewoodworker » Wed Mar 16, 2016 12:39 pm
Spot on we have had up to 5 teams on site. The current finish point will be full render on all walls, all electrics in and ready to switch over from the current 2 supplies we have, all water piping in and tested but no tanks or pumps yet, the septic system in, but no toilets fitted, the workshop ramp and parking area complete, and the floors actually flat, as they were supposed to be, so you don't have to use a thick bed of mortar under any tiles and can use thinset.
SWMBO wants at least the first undercoat of paint on as well.
We have too many window and door openings to be able to board them all up but may do the roof ones as they are only 50cm high. If we tried to do them all I think I would need over 40 sheets of plywood, not to mention the other wood to support it
Postby Sometimewoodworker » Thu Mar 17, 2016 9:37 pm
March 16~17th
Postby Sometimewoodworker » Sat Mar 26, 2016 7:09 am
March 18~20
The B team at work
Presure test at the correct pressure
Gifts from SSR and the PU foam people
The kitchen/living room with undercoat
Posts that need paint for the drain pipes
Another delivery of bags of render
Postby Sometimewoodworker » Sat Mar 26, 2016 7:22 am
March 22~24
It is now possible to get into the workshop as designed
The B team has been booted and the A team is back for a while
Secure parking
Delivery bay and parking area
Getting ready for the rainy season (we hope)
Postby Sometimewoodworker » Sat Mar 26, 2016 6:04 pm
March 24~26
Postby Sometimewoodworker » Wed Apr 06, 2016 3:04 pm
March 27~30
Finished blocking off the top windows
A flat floor going down
Gutter down pipes starting
Postby Sometimewoodworker » Wed Apr 06, 2016 3:20 pm
March 30~April 1
Temporary outlet pipes
SWMBO heard that there's cheap earth 250 per truck plus 100 for the tractor, so got 4
Some painting
More earth, more plants
The boss deciding on placement
