Postby Sometimewoodworker » Sat Aug 13, 2016 9:50 am
August 11-12th
Preparing for posting at 9:52 a.m. Saturday, 13 August 2016
Postby Sometimewoodworker » Sat Aug 13, 2016 9:55 am
August 12th
Preparing for posting at 9:57 a.m. Saturday, 13 August 2016
Postby pipoz » Sat Aug 13, 2016 10:46 am
Looking great, how long before its ready for you to move in
With your Roller Doors, did they have one that you could mount on the inside of the workshop wall
Postby Sometimewoodworker » Sat Aug 13, 2016 8:53 pm
pipoz wrote:Looking great, how long before its ready for you to move in
It could have been mounted outside (as it is) within the frame (but that would have dropped the clearance to 1.7m) or inside the workshop.
I have opted for the outside mounting so I can have an insulated security door inside and within the raw opening. We could easily have had it mounted within the wall bu increasing the doorway hight but then could not have sound insulted it easily.
I need the maximum sound reduction as the village has a ”no audible work after 6pm" rule, so I don't think that the shutter by itself will let me work late.
As to moving in the answer is when it's ready :lol: and since we have a place to live a few minutes away we don't have any time pressure.
Postby Sometimewoodworker » Mon Aug 15, 2016 8:42 pm
August 15th
A few details related to our roller shutter
The first point is that we could have payed about ⅓ the price we did. We are happy with the better specifications and the shutter.
First was to upgrade the thickness by about 6 grades from the thinnest 0.4 to 0.6 we decided against stainless steel as the difference is about 7 times more expensive.
Then we decided to have a subtle pattern on the individual sections.
After that we got quiet strips added to the shutter guides.
The next upgrade was to have roller bearings on the top roll up section.
After that we went for the larger size of roll, this also keeps things smooth and quiet.
The last two options were to have stainless steel padlock points, this is to prevent the hinges from binding over time (our current one has this problem).
And better quality side lock fitted (this delayed the installation as it had to be specially ordered from Bangkok)
The last thing that increased the price was to get the company to do the delivery and install
Preparing for posting at 8:09 p.m. Monday, 15 August 2016
Postby Sometimewoodworker » Tue Aug 16, 2016 8:08 pm
August the 16th
Details of mosquito nets
Preparing for posting at 7:53 p.m. Tuesday, 16 August 2016
Postby Sometimewoodworker » Tue Sep 06, 2016 10:50 am
August continued
Preparing for posting at 10:45 a.m. Tuesday, 06 September 2016
Postby pipoz » Tue Sep 06, 2016 12:14 pm
Great mosquito screens. I will need to get a set for my windows
Looking good, when do you start on the driveway :lol:
I will be back in Udon for a week, in a few days time, if you are in town
Postby Sometimewoodworker » Tue Sep 13, 2016 10:52 pm
August continued
Preparing for posting at 10:54 p.m. Tuesday, 13 September 2016
Postby Sometimewoodworker » Tue Sep 13, 2016 10:55 pm
August continued
Postby Sometimewoodworker » Tue Sep 13, 2016 11:01 pm
August continued
The fans that will go in soon
Postby Sometimewoodworker » Sun Sep 18, 2016 9:33 am
The helicopters have landed last night :)
5 days from order to delivery, ordered Monday lunch time, delivered Saturday evening :)
There was a bit of a panic last night because of the picture on the box showing a black fan
They have even put the location of the fans on the boxes
Panic over it is white
Preparing for posting at 11:24 a.m. Sunday, 18 September 2016
Postby Sometimewoodworker » Sun Sep 18, 2016 10:05 am
Planned locations of 4 of the fans and the cassette A/C
Looking up from the floor
Looking in through the bedroom window but this fan will have no light
Also Someone suggested a Big Ass fan
So I did some research and found that Big Ass fans could be good, if you have the space.
I hope they are a very much cheaper than MrKen D/C fans because they cost a lot more to run. (About 20x the power needed)
MK=MrKen 84" helicopter fan; virtually like for like.
Minimum space is 12' 8' for the fan + 2' on all sides :MK 7’ + (don't hit)
Minimum clearance 686mm : MK 530mm
Minimum hight under fan 3.05 m : MK no minimum (but don't cut you hair ;) )
Weight 35kg AC :MK 23kg DC
Power @ 120rpm 2.4A :MK 0.11A
Top speed 120rpm :MK 160rpm
No CFM quoted : MK 3070 to 8870 (0.043A ~ 0.35A)
Forward rotation only : MK forward and reverse
Wired wall control : MK wireless ( possibly wired option)
No price :MK on website
Warrantee, not clear :MK 10 years motor and 3 years rust proof
http://www.mrken-fan.com/products/view/design/607
http://www.mrken-fan.com/assets/product ... manual.pdf
http://www.mrken-fan.com/assets/product ... cation.pdf
http://docs.bigassfans.com/tech-specs/I ... -Sheet.pdf
FWIW
At the same rpm a MrKen uses 350 kWh per year if you run it nonstop (24/7/365)
A big ass fan uses 3,923 kWh per year (24/7/363)
Or about 2,500 baht more per year
Or 1 big ass fan uses much more than all 10 Mr Ken fans.
Postby AJBangkok » Sun Sep 18, 2016 11:33 am
I was looking to buy 5 fans for my patio and upstairs balcony areas but having seen these they would look awesome I think
AJBangkok
Postby pipoz » Sun Sep 18, 2016 12:14 pm
Hi
I have Mr Kens installed Helicopter 52 Inch & KEN 3D Solid Wood
CF#1 Helicopter 52 Inch, in a Brushed Nickle finish, in the Main Bedroom & Living areas (3 No), Weight 8.3 Kg. TB 8,645 each
CF#3 KEN 3D Solid Wood (Oak Blades) with a Brushed Nickle finish to Motor Housing, in Bedrooms 2 & 3 (2 No), Weight 6.1. (forget the price, but I think they were around TB 6,500, each)
CF#2 Helicopter 84 Inch, in a Brushed Nickle finish, in the Main Bedroom & Living areas (3 No), Weight 8.5 Kg. TB 9,405 each
All, DC motors, remote control, with six speed on the Helicopters and on the Mr Ken 3D's, made in Taiwan. Nice and quite.
Look at "Udon Thani Happy House" Page 20, 21, 25 & 26, for details/pictures. Last years prices.
Helicopter 52 Inch Remote Control 6 Speed TB 8,645
