Cape Yamu - Phuket
Cape Yamu - Phuket
Postby arranp » Sun Jan 11, 2015 11:11 am
land cost 4.5m, architect drawings being done, mine is LOT 2, green cone indicates sea view.
Site layout:
Site layout with proposed house ( green cones indicate sea view ):
following measurements are meters above sea level.
14m & 17m level ( ground and car park level ) :
20m level ( living & pool level ):
23m level ( bedroom level ):
roof overview:
front elevation:
arranp
Re: Cape Yamu - Phuket
Postby arranp » Sun Jan 11, 2015 2:02 pm
i want use clean energy.
my roof area is 23m x 13m and has the capacity to put circa 80 x 250 watts panels, total 20 kWh, however not necessarily looking to install an array this size, but looking for the efficient systems.
not interested in selling back to the grid. Will look at batteries for night time and lowest consumption to keep house cool, filter and pump its water.
open to advice on the systems to use. and want to harvest rain water.
my house is south facing.
house is not yet built so got a blank canvas
arranp
Postby schuimpge » Mon Jan 12, 2015 9:29 pm
Where is lot 2? Only see 1, 4 & 5 :roll:
Postby Shastadad » Tue Jan 13, 2015 7:38 am
Ditto, and the green cone seaview seems to be to be completely dependent upon no one building on lot 4 :?
Shastadad
Postby gliffaes » Tue Jan 13, 2015 7:54 am
I dont see anything that makes much sense looks like the photos are all truncated? Can you repost them a different size maybe?
Postby Roger Ramjet » Tue Jan 13, 2015 9:53 am
Lot 2 is in the first "photo" sketch on the top far right. The rest of the proposed house has been superimposed on the next sketches.
I would be more worried about my piles and foundations, along with the legitimacy of the chanote, than worrying about what the architect is paid to do..... what you tell him you want incorporated in the plans.
The spacing of the foundations and columns is so out of proportion to the size of the house I would be questioning the credibility of the "architect" who drew them. They will never get engineering approval.
Postby arranp » Tue Jan 13, 2015 10:51 am
all these I have done to show the architect.
architrct is yet to start working.
but you get the idea of what i'm looking for.
trying to make best use of the ses view, shown by the dotted sight lines.
been told i can have 6m span between columns.
arranp
Postby fredlk » Tue Jan 13, 2015 10:57 am
arranp wrote:been told i can have 6m span between columns.
But if your architect is Thai, your maximum span will be 4 metres.
Postby arranp » Tue Jan 13, 2015 11:11 am
yes normally 4m is the max. ive seen houses with longer spans. my friend is the builder, talk of pre tensioned beams.
don mueang airport has 10m spans.
so I guess wait and see what i get.
my friend is the builder, he has lived on the island for almost 20 years, partners in building one of the golf courses here and its housing estates. our daughters are in the same class at school, spent christmas day together, known him for 2.5 years, he was the first one to come see me at hospital after I had a bad smash here last june, our daughters frequently play at each other houses and have stay overs.
arranp
Postby fredlk » Tue Jan 13, 2015 11:21 am
arranp wrote:don mueang airport has 10m spans.
The elevated expressways have 20 metre spans but I doubt you would like to pay the very high price their construction will cost. The longer the span the more steel required.
Postby arranp » Tue Jan 13, 2015 11:24 am
I would like 6m including the columns but wait and see what i get back
arranp
Postby Roger Ramjet » Tue Jan 13, 2015 11:39 am
arranp wrote:I would like 6m including the columns but wait and see what i get back
What you would like and what the Or Bor Tor engineer will approve are two different things. Have you spoken with the Tesseban or Or Bor Tor engineers at all?
I can tell you now you should be more interested in the piles and the footings than anything else. If you are going to have a 6 metre span then you'll need not only a great Thai builder who understands plans, but also a lot of really heavy duty rebar and concrete that will pass a slump test every time.
fredlk wrote:The longer the span the more steel required.
And more concrete.
Postby arranp » Tue Jan 13, 2015 11:48 am
not spoken with anyone yet other than my friend the builder.
waiting for the plans, calcs and costings. will be 6 to 8 weeks so around end of march.
arranp
Postby gliffaes » Tue Jan 13, 2015 12:30 pm
OK I SEE the problem, the photos are all way too big, in google chrome you have to reduce the magnification of everything down to 50% to see ALL the photo, then you can see all the lots
Postby arranp » Tue Jan 13, 2015 12:39 pm
the coolest attic I have found upto now is white colourbond with PU insulation, like Fredlk has done in his Sattahip build, so this is what I would like to use on mine. 92% reflection and 92*F attic temp I believe during midday.
arranp
