Udon Thani Happy House
Re: Udon Thani Happy House
Postby pipoz » Thu Dec 07, 2017 1:59 am
Went to Boonthavorn with the TG to choose granite for the kitchen bench top.
So many options, but got down to the final four, Blue Pearl Light, Lavender Blue, Himalayan Blue and Tan Brown
The winner," Tan Brown" :roll: :roll: :roll: Her choice. Told her that she will be looking at it, for a long time after I am gone, so she better pick one she likes.
Now have to draw up the sizes, cut out positions/dimension and place the order. The only issue is, they (Boonthavorn) tell me the maximum length that I can get per piece, is 2.50 m long. I am going to be saddled with several joints, which I was trying to limit/eliminate. :roll: Price is around TB 4,300 per square meter, cut to the size.
Then amend the kitchen color/finishes scheme to accommodate the Tan Brown look
000 Tan Brown Granite Bench for Top - Boonthavorn on 01 Dec 2017 (2)
000 Tan Brown Granite Bench for Top - Boonthavorn on 01 Dec 2017 (1)
00 Lavender Blue Granite at Boonathavorn on 01 Dec 2017 (14)
00 Himalayan Blue Granite at Boonathavorn on 01 Dec 2017 (16)
0 Blue Pearl Light Granite at Boonathavorn on 01 Dec 2017 (13)
0 Multiple Options Granite at Boonathavorn on 01 Dec 2017 (8)
Postby pipoz » Thu Dec 07, 2017 2:20 am
At the same time picked the wall tile to the two main wall areas - Crystal White Carrara Marble Experience (its a Porcelain Tile, look a like). More uniform in appearance than natural marble and should not stain or discolor :roll: :roll:
Wall Tile Price was TB 51,414 for 66 No 90cm x 60cm Tiles & another TB 2,975 for 17 bags of Crocodile Wall Tile Adhesive. Works out to TB 1,236 per square meter, without labor cost
Crystal White Carrara Marble Experience on Left
WF Wall Finish - Crystal White Carrara at Boontharvorn (1)
Postby pipoz » Thu Dec 07, 2017 11:20 am
Floor Tiles: Still chewing over going for a light or medium light color floor tile or neutral look, so as to blend into the wall color and so contrast with the darker granite bench top.
Initially looked at Matt Non Slip tiles in Boonthavorn, from this range of 120 cm x 60 cm porcelain tiles, i.e. colors, Galena SQ, Pirite, Shadest San & Farfalla Mocca (Says Made in Italy but most likely Made in China), most of which are pretty neutral in color. In this range I am leaning towards either the Farfalla Mocca or the Pirite color :D
Then saw the Flow Light Grey Porcelain Tile (120 cm x60 cm) with a polished finish, at TB 1387 per m2 (from China), sitting next to a marble look tile, which gave me some idea of what a final look might be, between the wall & floor. Quite like the end result of the two colors/patterns, together. Think it will be easier to keep clean, but will be more slippery. Will probably go for this Flow Light Grey color look on the floor. :lol:
Flow Light Grey - Kitchen Floor to Wall Tile Concept (1) (Large)
Flow Light Grey - Kitchen Floor to Wall Tile Concept (3) (Large)
Flow Light Grey - Kitchen Floor to Wall Tile Concept (2) (Large)
00 Galena SQ 1075802 TB 2710 per m2 - Floor Tile Options at Boonthavorn 01 Dec 2017 (1) (Large).jpg
00 Pirite TB 2710 per m2 - Floor Tile Options at Boonthavorn 01 Dec 2017 (Large).jpg
00 Shadest San 1077030 TB 2.721 per m2 - Floor Tile Options at Boonthavorn 01 Dec 2017 (2) (Large).jpg
00 Farfalla Mocca TB 1388 per m2 - Floor Tile Option at Boonthavorn 01 Dec 2017 (1) (Large).jpg
Postby claynlr » Thu Dec 07, 2017 1:16 pm
" The only issue is, they (Boonthavorn) tell me the maximum length that I can get per piece, is 2.50 m long. I am going to be saddled with several joints, which I was trying to limit/eliminate. "
Pip- I know your counter is already constructed but you could lower a small section down a couple of inches or so where the cooktop sits to break up the longer length of the top?
claynlr
Postby pipoz » Thu Dec 07, 2017 2:33 pm
claynlr wrote:" The only issue is, they (Boonthavorn) tell me the maximum length that I can get per piece, is 2.50 m long. I am going to be saddled with several joints, which I was trying to limit/eliminate. "
Thanks and did think of that, but really want to retain the one level across the full length of the bench tops. So I have two options,
1.Stay with the one granite color (Tan Brown) to all bench top areas, keep it the one level and just accept another butt joint in the granite surface or,
2.At the bench ends (say for a 70-50 cm length) introduce a second granite color, either one which contrast's the Tan Brown Granite color and complements the wall or floor colors (say Camel Brown) or a second granite that works with the Tan Brown color and contrast with the wall/floor color (say Multi Color Red-Black)
I have seen it done before (two granite colors in a bench top area), where at the end of the bench top and the end vertical side piece were done in second granite color from that of the main bench area. Where they joined on the bench top the two granite's were cut to meet on a 45% angle, so it looked like an intended feature.
Just playing with ideas at this stage :roll: :roll: and also still have to decide whether I construct a long narrow Island Bench area
00 Camel Brown Granite
00 Multi Color Red Back Granite
HH Kitchen & Garden Pictures - 01 Dec 2018 (25) (M)
Postby Klondyke » Thu Dec 07, 2017 3:08 pm
Sorry, I did not read the whole thread. Why not to purchase the exact dimensions you want at a granite shop. Aren't you any nearby?
Years ago I did it so, no problem with any length around 3 - 4 m.
Postby pipoz » Thu Dec 07, 2017 3:31 pm
Thanks Klondyke,
Yes did try to get order my Granite in my lengths of 3.7 - 3.9 m plus, but haven't been able to find a Supplier who will accommodate me. Not so far.
Postby pipoz » Thu Dec 07, 2017 5:59 pm
Recessing into cavity wall and fitting off Circuit Breaker Board
Also continuing on with the additional GOP's and Power supply outlets
Power supply outlet in floor, for possible Island Bench
Wall GPO's and TV Outlet
0 HH Kitchen - Recessing & Fitting Breaker Board - 07 December 2017
0 HH Kitchen - Adding GPOs - 07 December 2017 (1a)
0 HH Kitchen - Adding GPOs - 07 December 2017 (1b)
0 HH Kitchen - Adding GPOs - 07 December 2017 (2)
0 HH Kitchen - Adding GPOs - 07 December 2017 (3a)
0 HH Kitchen - Adding GPOs - 07 December 2017 (3b)
Postby pipoz » Thu Dec 07, 2017 6:07 pm
Ceiling & eave framing, near complete
pipoz :D
0 HH Kitchen - Ceiling & Eave Framing - 07 December 2017 (2)
0 HH Kitchen - Ceiling & Eave Framing - 07 December 2017 (1a)
0 HH Kitchen - Ceiling & Eave Framing - 07 December 2017 (4)
Postby pipoz » Tue Dec 12, 2017 6:12 pm
Wall tiles and adhesive has arrived from Boonthavorn. Adhesive was meant to be Crocodile, but they delivered Weber :roll:
Ceiling works are all but finished :D
000 HH Kitchen - Ceiling & Eave - 12 December 2017 (1)
000 HH Kitchen - Ceiling & Eave - 12 December 2017 (2b)
000 HH Kitchen - Ceiling & Eave - 12 December 2017 (2d)
000 HH Kitchen - Ceiling & Eave - 12 December 2017 (2e)
000 HH Kitchen Wall Tiles & Adhesive - 12 December 2017
Postby pipoz » Thu Dec 14, 2017 4:12 pm
Just ordered a couple of Fans, Mr KEN's , off course :D
KEN Solid Wood Fans - DC Motor, Remote Control, RB Finish, Maple 52 inch, SP LED 1 Light & DR Down rod.
Think they are about TB 10,475 each, plus VAT & Shipping. WTF :lol:
KEN Solid Wood Fans - DC Motor, Remote Control, RB Finish, Maple 52 inch, SP LED 1 Light & DR Downrod.jpg
KEN SOLID WOOD 52 DC-DR
Mr Ken Fans - Page -17
Mr Ken Fans - Page-16
Postby pipoz » Fri Dec 15, 2017 3:24 pm
The TG found some shelving system to put up, in my tool room
Can finally tidy things up :lol:
Tool Room Install Shelving (2)
Tool Room Install Shelving (3)
Tool Room Install Shelving (6)
Tool Room Install Shelving (9)
Postby Sometimewoodworker » Fri Dec 15, 2017 3:58 pm
pipoz wrote:The TG found some shelving system to put up, in my tool room
What was the price & size on that?
So far I've been getting custom shelves built but that could be a reasonable alternative.
Postby pipoz » Fri Dec 15, 2017 4:08 pm
Sorry but Have no idea, STWW, as I am not there.
I will need to ask her where she bought it and come back to you
Final arrangement in Tool Room
Finished Tool Room Shelving (1)
Finished Tool Room Shelving (3)
Postby pipoz » Tue Dec 19, 2017 12:26 pm
For those interested in purchasing quality Fans, here is a link to Mr Ken's new catalog of amazing range of Fans
http://www.mrken-fan.com/catalog/
