Udon Thani Happy House
Re: Udon Thani Happy House
Postby pipoz » Sun Oct 15, 2017 4:51 pm
Now off to Boonthavorn for the Kitchen Hob and Hood :D
Went for 2 Sets,
Hoods: Siemens LC35S943TH 90 cm Chimney Hood - Touch control, reasonably quite & SS grease absorption filter system
Hobs: Siemens ER74232TH 67x45cm Gas 2 Burner Hob - Tempered glass, flame wheel wok burner system (whatever that means)
Hood & Hob was TB 19,900 per set and a 7-10 Day order delivery time
Kitchen Hood - Siemens LC35S943TH 90 cm Chimney Hood
00 12 Oct 2017 Siemens Boonthavorn Kitchen Equip (1) (L)
00 12 Oct 2017 Siemens Boonthavorn Kitchen Equip (2b) (L)
00 12 Oct 2017 Siemens Boonthavorn Kitchen Equip (3a) (L)
00 12 Oct 2017 Siemens Boonthavorn Kitchen Equip (3c) (L)
Postby pipoz » Mon Oct 16, 2017 10:16 am
After the rain comes the pumping out of the water, but were to :?:
Maybe its time to create a permanent pond in the back yard, with a few fish :roll:
At least the rear driveway is doing its job "as a bridge" :lol:
00 HH Pictures North side Soi 4 Driveway - on Friday 13 October 2017   (1) (Large).JPG
00 HH Pictures North side Soi 4 Driveway - on Friday 13 October 2017   (3) (Large).JPG
00 HH Pictures North side Soi 4 Driveway - on Friday 13 October 2017   (4) (Large).JPG
00 HH Pictures North side Soi 4 Driveway - on Friday 13 October 2017   (5) (Large).JPG
Postby pipoz » Mon Oct 16, 2017 10:39 am
At least the front yard is always nice a dry after a big rain. I have a slight fall on the driveway towards the front gate, so some of the rainfall just flows out onto the front road and vacant land outside
Garden is getting green and full. This has all grown in 3 years and just about all of the trees & palms were only 1 m high when planted. Doesn't take long to establish a garden scene in Thailand
So I will give it one more year and then start the flower garden beds and hardscape pathways and driveway paving. "Black Slate" if I can find a quarry in Thailand that produces larger size pieces
HH Pictures South Soi 5 Driveway - on Friday 13 October 2017 (2) (L)
HH Pictures South Soi 5 Driveway - on Friday 13 October 2017 (1) (L)
HH Pictures South Soi 5 Driveway - on Friday 13 October 2017 (4) (L)
HH Pictures South Soi 5 Driveway - on Friday 13 October 2017 (9) (L)
HH Pictures South Soi 5 Driveway - on Friday 13 October 2017 (11) (L)
HH Pictures South Soi 5 Driveway - on Friday 13 October 2017 (13) (L)
HH Pictures South Soi 5 Driveway - on Friday 13 October 2017 (16) (L)
Postby pipoz » Mon Oct 16, 2017 4:16 pm
Back to the kitchen and installing the steel wall beams and supports for the kitchen bench tops. Have two supports on the right side - either side of the Sink and one support on the back left side - midway between the cutouts for the two cook tops.
Sink Cut Out: The cut out for the sink in the bench top will be quite large - 1180mm x 480mm. This doesn't leave much meat on the granite bench top & support planks, running along either side of the sink. So will probably add a small frame under the sink and hang it of the steel supports, to carry the weight of the sink when full.
The granite bench top is to be independent of the eventual cabinets and or fridges, below it.
Eventually, I will set the Top of the Granite Bench Top at 880 mm above Finished Floor Level, leaving me 790mm clearance from FFL to underside of Bench, except where the steel support beams are 100mm lower.
Kitchen - Installing Steel for Granite Benchtop (1)
Kitchen - Installing Steel for Granite Benchtop (2)
000 12 Oct 2017 Siemens Boonthavorn Kitchen Equip (8) (L)
000 12 Oct 2017 Siemens Boonthavorn Kitchen Equip (11) (L)
Postby pipoz » Mon Oct 16, 2017 5:09 pm
Several perspectives of what the kitchen interior layout might look like, without the Island Bench area (at this time), in different colors.
The desired color will be one of either Purple Violet or Blue Violet or Burgundy Red, but the perspectives cant quite catch the intended color.
Will leave the TG to pick her desired color, since as she will be looking at it long after I have gone :roll:
Purple Violet Kitchen (2)
Burgundy - Maroon Kitchen (1)
Blue Violet Kitchen (7)
53_philip3.2
52_philip3.1
48_PHILIP02
49_PHILIP03
Postby pipoz » Tue Oct 17, 2017 10:25 am
Kitchen: and the steel beams go up for the two glazed wall assemblies (one front & one left side)
The top window section assembly is likely to be a simple UPVC Center Hung Pivot window, rectangular shape (90cm L x 60 cm H)
UPVC Center Hung Pivot Window - Rectangular
UPVC Center Hung Pivot Window - Rectangular.jpg (11.84 KiB) Viewed 216 times
Kitchen - Installing Steel for Glazed Assemblies (1)
Kitchen - Installing Steel for Glazed Assemblies (3)
Postby pipoz » Tue Oct 17, 2017 1:54 pm
Kitchen block walls underway. This is day 3, so by Friday (day 6) the block walls should just about be complete. :D
Have a small crew of 4 (Husband & wife team from Buriram with 2 local Friends), installing the steel work to the bench & windows, plus moving all the blocks from north side of the driveway, laying the blocks and doing the render inside and outside walls/columns
I expect they will take about 10-12 days to do all of the Work, and I will pay them TB 30,000, plus given them room and food for the 12 days. Works to walls is laying 40 sqm (40mm Wide inside block + 70mm Wide Block skin), plus a concrete lintel over the double door and then about 104 sqm of render (to inside/outside wall, column & concrete ring beam)
Electrician is due to start working with them tomorrow :D
Kitchen Blockwork on 17 October 2017 (2)
Kitchen Blockwork on 17 October 2017 (3)
Postby Kolac » Wed Oct 18, 2017 4:47 am
great project and very nice house
Kolac
Postby pipoz » Wed Oct 18, 2017 10:21 am
Kolac wrote:great project and very nice house
Thanks and still have about a year to go before it is all finished
And then I move to Thailand :lol:
Postby pipoz » Wed Oct 18, 2017 10:41 am
Decided to cut our first tree down. Actually I do have a chainsaw and he did eventually use it :lol:
Will slowly remove a few trees to thin out the land scape
T HH Pictures Cutting Down Tree - on Friday 13 October 2017 (1) (L)
T HH Pictures Cutting Down Tree - on Friday 13 October 2017 (2) (L)
Postby pipoz » Wed Oct 18, 2017 12:20 pm
More progress as the kitchen walls go up. This is Day 4 of the kitchen steel work & walls and I expect they will finish the block walls on Friday (Day 6). Then start the Render
The Supervisor is the short one - sitting on the blocks, as I a not there. Might have to give him a Salary :lol:
00 Kitchen Walls - 18 October 2017 - Day 4 -HL (2)
00 Kitchen Walls - 18 October 2017 - Day 4 -HL (3)
00 Kitchen Walls - 18 October 2017 - Day 4 -HL (4)
0 Kitchen Wall - 18 October 2017 - Day 4 - YFB (3
0 Kitchen Wall - 18 October 2017 - Day 4 - YFB (4)
Postby pipoz » Wed Oct 18, 2017 6:43 pm
Forgot to make sure he puts the holes in the wall (right size and right place) for the Hood Exhaust/Extraction
So punched out a drawing and photo, hoping he gets it in time :roll:
000 Kitchen Hood Holes in Wall -8075-009-R6
Postby pipoz » Thu Oct 19, 2017 2:33 pm
Shifted some of the old kitchen gear out towards the new Larger Kitchen area
Then demolished the Old Bamboo Hut Kitchen :lol:
Then started a new small temporary structure, which will be a short term kitchen, until the new Larger Kitchen is completed, some time next year. Then this new small temporary structure, may then become an undercover BBQ area. :roll:
00 Demolish Old Kitchen & Clean Up - 19 October 2017 - Day 5 (3)
000 New Small Temporary Structure - 19 October 2017 - Day 5 - BBQ (1)
Postby oldschool » Thu Oct 19, 2017 7:25 pm
just finished reading your story.took me nearly two days,i am most likely going to do a post on here about a recent build i have done with my missus.it wont be quite as detailed as your storey but after reading this one i feel it must be shared all the same.You certainley have built one great retirement pad there and set youself up very nicely for retirement. the detail you have gone to in planning and explaining your storey is incredible.I hope you get too enjoy it to the max.regards.
oldschool
Postby pipoz » Thu Oct 19, 2017 7:31 pm
oldschool wrote:just finished reading your story.took me nearly two days,i am most likely going to do a post on here about a recent build i have done with my missus.it wont be quite as detailed as your storey but after reading this one i feel it must be shared all the same.You certainley have built one great retirement pad there and set youself up very nicely for retirement. the detail you have gone to in planning and explaining your storey is incredible.I hope you get too enjoy it to the max.regards.
Thanks Oldschool and the plan is to enjoy the peace and quite once I finish working in this S..Hole
Maybe I can turn it into a book and then a movie, to recover some of the money :D
Either way, welcome to Udon Thani, assuming you are intending to retire in the general area. Looking forward to reading your storey
