Udon Thani Happy House
Re: Udon Thani Happy House
Postby Mike Judd » Sun Aug 10, 2014 8:18 pm
By the way you guys, using those Thai scaffold frames, unless you want to risk it all falling over, the "Rule of Thumb" safe height is no more than 3 times the width unsupported. Any more then that and it should be tied into the building / braced outwards to increase it's base, or just a piece of rope to restrain it from going over. :roll: :roll:
Postby schuimpge » Mon Aug 11, 2014 5:41 am
Roger Ramjet wrote:Pipoz,
If you are going to buy the drill press you can also buy larger chucks for them to tale the larger drills. Just be warned that the presses are made in China and won't last if you go for heavy drilling without using oil on the drill bits the whole time. For a few thousand baht more you can get Makita or Maktec that will last a lifetime.
Thai Watsadu have an excellent range of power equipment, it's a pity the kids try and flog the American brands when the Japanese ones are far better.
The drill press show is like 1800 Baht in my local market.
Never buying tools, except consumables like sandpaper, in the big shops. Too expensive. Bought a copy B&D hammer in the market 3 years ago and it's been used extensively in my renovation. Never gave a problem.. Less than 2000 baht.
Having a problem? I just go back and the guy repairs it on the spot.
Postby pipoz » Mon Aug 11, 2014 10:13 pm
Finally stripped out the formwork. Concrete is a bit rough but not a structural issue
Still trying to decide whether to knock down the 4 columns in the center front. Will decide after I see the roof go on.
The Roofer has delayed his start from 10 August to late August, because my roof tile colour (Black Steel) is apparently not available until mid September
Front View Half Way to Gate
Front View R
Front View L
View from West Side
View from West Side
Postby pipoz » Thu Aug 14, 2014 11:10 am
For those of you who haven't decided on or started your roofing, I found this in Thaiwatsadu last week - Diamond Ultra Truss
Didn't take to close a look as I had already decided on the Top Hat system from Home Mart
Diamond Ultra Truss
Diamond Ultra Truss and Tile
Diamond Ultra Truss
Postby pipoz » Thu Aug 14, 2014 11:15 am
For those of you interested in the cost of Plasterboard at Thaiwatsadu
Gyproc 12 mm thick, 1200 x 2400 mm TB 159 per sheet
Gyproc 9 mm thick, 1200 x 2400 mm TB 136 per sheet
Postby pipoz » Thu Aug 14, 2014 11:20 am
For those of you looking for some Kitchen Cooker Tops. I have gone for the 3 Burner TB 8,290 for the Outdoor cooking bench under the Sala, as type of BBQ
3 Burner Gas TB 8,990
3 Burner Gas TB 10,990
3 Burner Gas TB 8,290
Postby pipoz » Thu Aug 14, 2014 6:06 pm
For those interested in the cost of Light Fittings and External Lamps & Posts
Internal Fittings
Internal & External Fittings
Internal Fittings
Internal Fittings
Internal Fittings
Internal Fiitings
Postby pipoz » Thu Aug 14, 2014 6:10 pm
A few more light fittings, lamps and posts
External Lamps
External Lamps
External Lamps
External Lamps
External Lamps
Internal Fittings
Internal Fittings
Postby pipoz » Thu Aug 14, 2014 6:12 pm
Just a few more lamps and posts at Thaiwatsadu
External Lamp Posts
External Lamp Posts
External Lamps
External Lamps
Postby gippy » Fri Aug 15, 2014 9:05 pm
I have that large drill press. It's a Rexon from Taiwan. It's a solid bit of kit and I am very happy with mine.
gippy
Postby pipoz » Sat Aug 16, 2014 11:15 am
gippy wrote:I have that large drill press. It's a Rexon from Taiwan. It's a solid bit of kit and I am very happy with mine.
Hi Gippy
Can I ask where did you buy yours from (Global, etc) and do you have a picture of it. Also may I ask how much it cost
I need to buy one to build my Cafe Racer like the one below
Yamaha Cafe Racer
Postby gippy » Sat Aug 16, 2014 12:30 pm
Hi Gippy
I got it from Thai Watsadu. It was just under 10k baht if I remember correctly. I use it mainly for woodworking so I built a larger table with a fence, also added a mobile base so I can roll it around as required.
I took this photo when I finished building the base, it's nowhere near that tidy now, off to clean up the shop a bit :D
gippy
Postby pipoz » Sat Aug 16, 2014 12:59 pm
Thanks Gippy, yes its the one I saw for TB 9,680 at Thaiwatsadu
Rexon Drill Press
Postby sirineou » Sat Aug 16, 2014 8:41 pm
gippy wrote:
Hi Gippy
Hey Gippy
That's way to nice of a table for a drill press, if my wife see it, she would put a doily on it or put a lamp shade the drill press,:lol: I have furniture in my house that is not as nice
you do nice work :D
Postby pipoz » Sun Aug 17, 2014 12:25 pm
Day 88 Roofer arrived to start framing. Nothing much happened since the last concrete pour on 11 June, until now, other than selecting the roofer and the colour of the roof tiles.
The Turtle moves again, but the Roof Tiles are no expected until later September
Day 88 - 16 August 2014 Roof Framing Starts
Day 88 - 16 August Roof Framing Starts
Users browsing this forum: Google Adsense [Bot] and 2 guests
