Udon Thani Happy House
Re: Udon Thani Happy House
Postby pipoz » Sun Aug 03, 2014 6:51 pm
I like the split look and colour of the one at the top. Think it is around TB 2,300 per m2
Special Offer
Postby pipoz » Sat Aug 09, 2014 1:42 pm
May not be the most appropriate place to post, but in my travels through Thaiwatsadu I found the following Form work items and costs.
No bad and will certainly buy some for my next stage
Metal Forms 1200 x 400 mm TB 459 each
Metal Forms 1200 x 300 mm TB 350 each
Acrow Prop (Copies) TB 525
Postby pipoz » Sat Aug 09, 2014 1:59 pm
May not be the most appropriate place to post, but in my travels through Thaiwatsadu I found the following Scaffolding frame, braces, wheels etc and their costs. No a bad price, if I am reading the price tags correct.
All up a simple two fame high mobile type scaffold, appears to be around TB 10,000 plus the cost of some sort of deck + a bit of tube & some clips. Didn't see an Clips floating around but sure that someone will sell copies somewhere
Mike, this must make your eyes water. I know they are copies, but what at 1/50 of the cost of similar ones in Australia, they look OK of light ceiling, painting and or outside cleaning of gutters around the house. Treat them with care and they might last 10 years
Frames TB 1,480 each
Frames TB 1,370 each
Frame X Braces
Scaffold Frame Joiners TB 20 each
Header (Adjustable in Height) TB 185 each
Wheels TB 379 each
Postby Sometimewoodworker » Sat Aug 09, 2014 8:58 pm
pipoz wrote:May not be the most appropriate place to post, but in my travels through Thaiwatsadu I found the following Form work items and costs.
You can probably hire the forms for about ฿3 per piece per day, which makes better sense than buying.
Postby pipoz » Sat Aug 09, 2014 9:27 pm
Yes, but am going to try and get a nice "Off Form Concrete" quality finish (maybe with a light water cut-sand blast) to some external areas in the next stage, so want some new forms and some good form oil. Even contemplating putting a black pigment into the concrete mix to get a Basalt look
Postby Sometimewoodworker » Sat Aug 09, 2014 9:34 pm
I'll be very interested in seeing how that turns out.
Postby pipoz » Sat Aug 09, 2014 9:41 pm
pipoz[/quote]
I'll be very interested in seeing how that turns out.[/quote]
So will I
Postby Mike Judd » Sun Aug 10, 2014 6:45 am
When I first saw those A frames/H frames what ever years ago I dismissed any ideas of bringing over my light weight Alloy scaffolding, so cheap and they do the job, and thats all that matters. I bought 4 frames with the braces and 4 wheels and Boy ! did they make use of them, mind you they did only have a single piece of wood as a plank ,not bothering with the deck that I made for it. ? T.I.T. :roll: :roll: :roll:
Postby Roger Ramjet » Sun Aug 10, 2014 6:58 am
pipoz wrote:May not be the most appropriate place to post, but in my travels through Thaiwatsadu I found the following Scaffolding frame, braces, wheels etc and their costs. No a bad price, if I am reading the price tags correct.
Thanks for that pipoz, I intend buying eight, just for those little annoying things that always go wrong near the roof and a lack of equipment to fix it.
I have heaps of storage space so they'll just be for "emergencies".
Postby pipoz » Sun Aug 10, 2014 10:49 am
I think they are excellent value for the handy man issues. I just has to find where they sell some copy scaffold clips that fit the local tube size or I will weld some lugs on at various heights, so that I can bolt a timber work platform
Postby pipoz » Sun Aug 10, 2014 11:13 am
For those who haven't been shopping at Thaiwatsadu and are curious as to what tools can be found in Thailand (in my view everything) some prices of Power tools, Hammers and Tile Cutters
I went an bought the larges Bosch Power Drill, it was TB 10,300 vs the Makita one for TB 7,390, but looked a bit bigger. Same with the Angle grinder bought the largest Bosch version for around TB 5,000.
For some reason I prefer Bosch to Makita, as back in Oz I had a Bosch Hammer drill that lasted me 10 years without a problem. Not sure where the Thaiwatsadu version of Bosch is manufacturers, but it didn't say China. Most likely in Thailand
Makita Drills
Makita Wood Tools
Makita TB 4,200
Kanga Type Hammers Bosch & Makita
Small Drill Press TB 6,550 & 9,680
Tile Cutter TB 4,850
Postby Roger Ramjet » Sun Aug 10, 2014 11:30 am
Pipoz,
If you are going to buy the drill press you can also buy larger chucks for them to tale the larger drills. Just be warned that the presses are made in China and won't last if you go for heavy drilling without using oil on the drill bits the whole time. For a few thousand baht more you can get Makita or Maktec that will last a lifetime.
Thai Watsadu have an excellent range of power equipment, it's a pity the kids try and flog the American brands when the Japanese ones are far better.
Postby pipoz » Sun Aug 10, 2014 11:57 am
Roger Ramjet wrote:Pipoz,
Thanks Roger, if I do buy a drill press, I will only be using it for drilling aluminium mainly for bike parts. Any heavy or steel drilling I will get done down the local metalwork shop and use his equipment.
For the around the house work power tools, are you talking about Dewalt. I stay away from Dewalt and Black & Decker
Postby Roger Ramjet » Sun Aug 10, 2014 2:33 pm
pipoz wrote:For the around the house work power tools, are you talking about Dewalt. I stay away from Dewalt and Black & Decker
Primarily Black and Decker. When I was in the US every workshop I walked into had a corner where discarded B & D tools that had shat themselves a month after the warranty ran out, lay. They did not have a good name..... but ask any American why they continue to buy them and they'll give you a blank stare.
Can't say anything about Dewalt because they sponsor Marcos Ambrose's number 9 Nascar and also feature in a Canadian rebuilding show (can't remember the name of it) where shonky workmanship is fixed, but I still don't think you can go past the Japanese for power tools that last.
Postby sirineou » Sun Aug 10, 2014 6:46 pm
Ask this American about B&D tools and you will not get a blank stare . :D people buy them because they are inexpensive. B&d tools are owned by the same company that owns DeWalt among many other brands of tools.
DeWalt tools IMO are very well made, I buy them for the company I work for , and we are very rough with them. They constitute a good balance between quality and price.
Classifying tools by nationality is no longer relevant as the companies can be headquartered in one country, can own other companies from different countries, and share engineering and parts, and are manufactured anywhere in the world the parent company finds profitable. Dewalt tools are owned by Stanley Black and Decker but is marketed by a division of the Spectrum Brands, :o who owns other tool companies from all over the world.
You are beging to get the picture.
By the way, many Thanks to Pipoz for posting all the pictures and prices of the tools available in Thailand :)
