Water-House Extended time line
Re: Water-House Extended time line
Postby Sometimewoodworker » Sun May 12, 2013 3:44 pm
Making a table to help with the job.
We decide on making a table as well
table
table
We rather like blue
A side job
The base of the water house
Adding side reinforcement
Making sure that the joints are really secure.
reinforcement under joints
Everything gets supported
Floor setup
Postby fredlk » Sun May 12, 2013 3:51 pm
Maybe I'm a bit early with my question but the suspense is killing me. How are you protecting all the steel against rust and are you taking it as a given that you will be repainting it every few years?
Postby Sometimewoodworker » Sun May 12, 2013 3:53 pm
Getting on with the base of the Sala
The base in progress
Na-Sit's wife helping the building
Helping tighten the fixing bolts
Added corner piece
the base in progress
Post support with topcoat
view from the far bank
Last edited by Sometimewoodworker on Sun May 12, 2013 4:04 pm, edited 1 time in total.
Postby Sometimewoodworker » Sun May 12, 2013 4:03 pm
fredlk wrote:Maybe I'm a bit early with my question but the suspense is killing me. How are you protecting all the steel against rust and are you taking it as a given that you will be repainting it every few years?
Its all painted with the grey rust protection primer and will be top coated in white.
Postby Sometimewoodworker » Wed May 15, 2013 6:43 pm
Things started moving a a reasonable speed
We are going to use 3 metre floor boards so with a 4 x 4 metre base we had to have supports at 1 metre centres. But the foundation pillars didn't permit. So the Oxy-Propaine cutter got some more work.
The floor must have support at 1 metre centres but the foundations get in the way.
A wider view of the second steel level.
Second level of steel
Na-Sit is proud of his magnetic level and is showing me that he cares if things are plumb.
Making sure that the uprights start vertical.
Corner upright with temp stabilisers
Corner upright stabiliser and base plate with temp bottom suppoet
Postby Sometimewoodworker » Wed May 15, 2013 7:00 pm
Making sure that the sides are really equal
Ensuring the sides are equal
Wide view with temp.supports
Wide view with 4 main posts
Wide view with temp.supports halfway up to give something to stand on when fixing the roof steel.
Some of the steel has had a top coat
Wide view with 4 main posts and some of the upper steel painted
Here is my baby compressor that can just keep up with the spray gun.
The baby compressor that is getting a real workout
This was the point we had to go down to Bangkok to come back to work in Japan
Postby Sometimewoodworker » Wed May 15, 2013 7:13 pm
We were in Bangkok and Na-Sit was continuing working. His daughter is now taking the Pics so we can see what is going on.
The roof structure is starting to appear these are posted 0n April 8th.
The roof structure is coming together
There are now 4 temporary uprights from the posts to make sure the top level is level.
Wide view
Postby Sometimewoodworker » Fri May 17, 2013 2:48 pm
We were back in Japan and relying on Skype calls and pics
good support everywhere
posts are capped
After welding everything gets painted again
More steel joints
Working hard in the heat
Lots of steel joints
An overview of progress
Postby Sometimewoodworker » Fri May 17, 2013 2:59 pm
High level working
High level working
Another whole structure view
The frame is coming along nicely
Postby Nawty » Fri May 17, 2013 7:53 pm
Why didn't they sit it on top of the concrete piles instead of basically sitting all the weight on top of 2 bolts through the piles ?
Nawty
Postby Sometimewoodworker » Sun May 19, 2013 2:32 pm
Nawty wrote:Why didn't they sit it on top of the concrete piles instead of basically sitting all the weight on top of 2 bolts through the piles ?
It's easy to get things level with brackets. There are 8 16mm bolts so first you have to overcome the friction then shear through them so it's unlikely to be a problem
Postby Sometimewoodworker » Sun May 19, 2013 2:40 pm
The Baby compressor is getting a workout and the higher level steel is getting a topcoat.
safety equipment is sometimes used when provided
Reloading the paint cup
Postby Makmak456 » Sun May 19, 2013 3:29 pm
looking good !
Mark
Makmak456
Postby Sometimewoodworker » Tue May 28, 2013 8:09 pm
The whole family is getting in on the construction.
Na-Sit's daughter getting in on the act
There is going to be a watertank in the roof.
Water tank hatch
Water tank hatch 2
Water tank hatch 3
ater tank hatch 4
Welding the base of the uprights.
Base of upright
Detail of the weld quality.
Weld quality
Postby Sometimewoodworker » Tue May 28, 2013 8:18 pm
The water tank can be replaced using the removable section.
Tank hatch 1
Tank hatch 2
Na-Sit is makeing good use of the dust mask I've lent him. He is now starting on the walkway posts
7" angle grinder fun
More 7" angle grinder fun
The concrete is really good
Getting good use of the new SDS drill
Success
