Nakhon Sawan House Build 225sqm 2.25mil
Re: Nakhon Sawan House Build 225sqm 2.25mil
Postby arranp » Thu Jun 28, 2012 9:58 am
first piles being made.
arranp
Postby dozer » Thu Jun 28, 2012 7:21 pm
A slight terminology correction, piles are driven into the ground or drilled into the ground (normally where the soil conditions are not optimum or for a very large structure), they are working on the framework for the columns (or posts).
edit notation: rec'd this PM from someone indicating may be piles: I think if you look at the picture they look round and are quite likely for bored piles -- if so ignore above comment.
Postby arranp » Sat Jun 30, 2012 9:55 am
migh thats a big one!
a little bit of acrobatics pouring the concrete... (these guys work long hours but I guess its cooler at night)
arranp
Postby arranp » Sat Jun 30, 2012 9:57 am
yes, alot of water underground here, 10 metres down and still wet clay.
arranp
Postby dozer » Wed Jul 04, 2012 8:33 pm
OK, thanks for correcting me, good example of bored piles.
Postby Roger Ramjet » Thu Jul 05, 2012 7:03 am
arranp,
Thank you for the photos, it just proves there is at least one auger earth in Thailand...well at least the drill part of it.
Postby arranp » Sun Aug 05, 2012 7:46 am
arranp
Postby gliffaes » Sun Aug 05, 2012 12:55 pm
It sure looks like you have some sticky gloop on your land, Im glad my land in a way is almost all rock.
Postby arranp » Fri Aug 10, 2012 5:02 pm
16 footings for the house are in, still to go are the 4 footings for the terrace which I guess they will do at a later stage because their workmans shack is located over them at the moment.
Also they have blessed two of the columns which I believe is common practise for Thais when building a new house.
arranp
Postby gliffaes » Fri Aug 10, 2012 5:37 pm
arranp wrote:16 footings for the house are in, still to go are the 4 footings for the terrace which I guess they will do at a later stage because their workmans shack is located over them at the moment.
Good luck keep your eye on them at all times, no blessing at my house they just got on with it.
Postby arranp » Sat Aug 25, 2012 11:05 am
foundations done, ground floor columns being set.
arranp
Postby arranp » Mon Aug 27, 2012 9:16 am
arranp
Postby Fritz » Mon Sep 03, 2012 1:18 pm
I got your email on Saturday. Anyhow, good luck with your project. Whereabouts are you building in city?
Fritz
Postby arranp » Thu Sep 06, 2012 9:19 am
arranp
Postby sirineou » Thu Sep 06, 2012 10:09 am
What a difference from the muddy mess of doing the foundation footing, Looks like they are doing nice clean work with the columns.
Looking forward to seeing the upstairs poured.
It's beginning to look like a house :)
Good luck
