payebacs wrote:gliffaes wrote:payebacs wrote:The house looks great Gliffaes. 450k...
I'm hoping to build slightly bigger (12 x 6) and for less so probably need to start contemplating exactly where these reductions in price are going to come from.
You could use single block walls and bigger overhangs..... personally wouldnt use aac blocks... ask for a slump test.......Roof steel , shop around.....steel colorbond type roof.....do it yourself with workers.....Shop around....Boonthavorn is expensive.....be on site ALL day.......never be afraid to tell them its wrong.
Thanks gliffaes. The roof does seem quite majestic. Just the tiles must set you back a bit. Single block, hard to say. Perhaps save for longer and do it the 7K m2 guideline way. not sure. Is it okay to build in stages ie. foundations, uprights and slab first followed by a year break or will all that sun and rain be too much. If you could build in year-long-gap stages what would those stages be? Roof, walls? Or is it unavoidably better to build all in one?
I think Id try and do it all at once unless the local labour is readily available. Once you find some half decent blokes you need to keep them.
If I was to split it up id get to the roof stage ie roof on, Id be worried that all manor of life would then move into the roof though such as birds although that cheap green netting fastened up inside would keep em out.
You could do it for less than 7k if you dont hire a builder like I did, however he did supply me with a concrete vibrator, floor power float all timber , makro etc etc so all in al it wasnt too bad a deal.
The roof tiles (I think) well you can choose the cheapest colour and ALL homemart stores ( cpac tile distributor) have different prices and you can call several and haggle between them, just say you got them for 11 baht and call another and say 10.5 etc.
Just use double block on hot walls or design with a bigger roof overhang so no sun hits the walls.
I chose my tiles as they were the lightest cpac colour to reduce heat build up price I think was about 12 ish baht each.
They still get hot but not as hot as the other colours.
