Our house build in Hua Hin
Postby CDNinKS » Sat Jul 02, 2011 4:02 pm
As a few people watching my pool build thread wanted some pics of the house build, here are the first 7.....
CDNinKS
Re: Our house build in Hua Hin
Postby CDNinKS » Sat Jul 02, 2011 4:05 pm
7 more
CDNinKS
Postby CDNinKS » Sat Jul 02, 2011 4:08 pm
7 more
CDNinKS
Postby CDNinKS » Sat Jul 02, 2011 4:11 pm
7 more
CDNinKS
Postby CDNinKS » Sat Jul 02, 2011 4:13 pm
where we are now...
CDNinKS
Postby BKKBILL » Sat Jul 02, 2011 7:20 pm
Great stuff CDN do like the steel beam at the head of pool.
Good to see a long span supporting a lot of roof without posts.
Postby CDNinKS » Sat Jul 02, 2011 11:54 pm
Thanks Bill.....and the best part is I didn't have to calculate the snow load :lol:
CDNinKS
Postby geordie » Sun Jul 03, 2011 2:00 am
Cracking place looks great all round same as bill love the trusses the pool goes down some distance what was the maximum depth for the tank
the roofer looked to be good too, some nice lines there
Postby CDNinKS » Sun Jul 03, 2011 2:54 am
The tank is a bit over 3 meters deep, about 45,000 liters capacity but that would be right to the top. With inlets and overflow pipes probably more like 40,000 usable.
CDNinKS
Postby geordie » Sun Jul 03, 2011 4:30 am
Deceiving loked several times trying to guess i thought four mtrs below grade but your ground beams look taller than the norm as well so its probably the camera combined with angle,s is that a prefab fence around the place it looks nice ?
As for reserving judgement on the builder i don,t blame you its usually the fine touches that the job falls down and the stress begins :( :( did you do your own design ?
Postby CDNinKS » Sun Jul 03, 2011 4:34 am
Yes, pre-fab fence by Ready Fence. My own design for the house, drew up the floor plan with software and then a local guy here did the actual plans.
CDNinKS
Postby BKKBILL » Sun Jul 03, 2011 8:45 am
Here is the fence link from google translate.
http://translate.google.com/translate?j ... 2F&act=url
Postby pattayapope » Mon Jul 04, 2011 11:43 am
CDNinKS wrote:My own design for the house, drew up the floor plan with software and then a local guy here did the actual plans
I did exactly the same on my build but the plans were not very detailed and left me exposed for extras at the end, your design looks very similar to mine except I ended up with the pool at the side of the house. Did you put any corridoors in or are are the rooms only accessable from outside. If I built again I would change a few things but I am still quite pleased with the result.
This forum and builds done by my friends helped a lot and saved quite a few pitfalls along the way, the house ended up costing just under 4 million and the pool \ carport \ pump house another 1.2 million. If possible can you post a floor plan and best of luck with completing your build and keep the pictures comming.
Postby CDNinKS » Thu Jul 07, 2011 2:28 am
Yes, the house has corridors inside. I tried to post a pdf of the floor plan from the punch software I used but the file was too big. Will try a different approach when I get a minute.
CDNinKS
Postby CDNinKS » Sun Jul 10, 2011 8:58 am
A few more pics....
CDNinKS
