very slow build between Kosumpisi and Khonkaen
Re: very slow build between Kosumpisi and Khonkaen
Postby BKKBILL » Mon Jun 02, 2014 8:26 am
Mike Judd wrote:Pipoz.! I'll have a look, it's my second home .!
:D
Postby Mike Judd » Mon Jun 02, 2014 11:34 am
They come in 30mt rolls, the plastic 110m.m. wide is $7 per roll, going up in widths 150m.m. /230mm/250m.m./300m.m. /350m.m. with the prices going up accordingly. The same sizes in bitumen covered aluminium is roughly 4 times the price of plastic. but they do have 10mt rolls in aluminium.
Postby pipoz » Mon Jun 02, 2014 1:59 pm
Mike Judd wrote:They come in 30mt rolls, the plastic 110m.m. wide is $7 per roll, going up in widths 150m.m. /230mm/250m.m./300m.m. /350m.m. with the prices going up accordingly. The same sizes in bitumen covered aluminium is roughly 4 times the price of plastic. but they do have 10mt rolls in aluminium.
Thanks Mike.
In my case its will be my first home (this time round), as I keep giving my homes away to the Ex's
Postby pipoz » Thu Jun 05, 2014 8:30 pm
Thanks Mike, I think I have found it over here. Name is PLUVEX and comes from UK. - Hyload Pluvex No 1 or Pluvex No 2.
Rolls look like they are 8 m long.Off to see how much it costs a roll tomorrow.
DPC Pluvex-01-10.pdf
Pluvex
(44.63 KiB) Downloaded 28 times
Postby Mike Judd » Fri Jun 06, 2014 6:26 am
Pipoz,! That may well be the same stuff .but 8mt rolls seem a bit small, more like the lead rolls that you can still get here used for flashing or special applications. I'll take a photo of the plastic and post it tomorrow. Mike.
Postby Roger Ramjet » Fri Jun 06, 2014 7:06 am
The three rolls I bought at Thai Watsadu were 90 metres long and two metres wide. They cost 1,000 baht each.
Postby Mike Judd » Fri Jun 06, 2014 8:52 am
R.R. I think we are talking about a different application here, you are probably talking about the black underlay that you can use under a slab or pavers to primarily stop weeds growing through, as well as with a slab keep the cement seeping out. The orange Forticon plastic is mainly used here for slabs ,comes in heavier thicknesses and various lengths plus up to 6mt wide. What Pipoz and I are discussing is brickwork damp proof courses which used to be lead but now days, bitumen coated aluminium or the diamond patterned plastic that I used. No walls in Oz or England (Can't speak for the rest of the world) would be laid without a D/P/C on the slab or foundations just clear of the ground. With cavity face brickwork (Not rendered) rain would penetrate the outer face through the cement joints and run down inside to the bottom and soak through the inner skin, so a wider roll is used( They come in multiple brick widths) that is one or two bricks higher on the inside sloping down to the outer and directing the water out through weep holes left in the brickwork every 1 mt or so. With Thai construction usually rendered and with a good quality paint, all that can be omitted , but you can still get moisture coming up with a capillary action from below into any wall ,especially if no under lay in the slab or foundations in the ground. Paint peeling off at the bottom of walls is a clear indication of that problem.
Postby Mike Judd » Sat Jun 07, 2014 9:55 am
split granite veneer
Latest info from the 2 guys left working on the house is that the drains have been rendered ready for flushing out, so that the outlet pipe that I put in half way round can have it's cap screwed on and the inlet pipe to the tank opened. Then we will see how long it takes to fill up. ?
They are starting on the split granite stone veneer to all the house walls up to sill height next, that should keep them busy for a while.
Postby pipoz » Sat Jun 07, 2014 10:27 am
Hi Mike, how are you fixing your split stone to the walls
Postby Mike Judd » Sat Jun 07, 2014 12:36 pm
The bottom black tile goes on using cement as it has to be sloping ,then they have a tile adhesive as supplied with the stone, using a notched trowel same as fixing wall tiles the western way, except there's no joints.
Postby pipoz » Thu Jun 19, 2014 9:30 pm
Mike Judd wrote:Pipoz,! That may well be the same stuff .but 8mt rolls seem a bit small, more like the lead rolls that you can still get here used for flashing or special applications. I'll take a photo of the plastic and post it tomorrow. Mike.
Thanks Mike, cracked it and found the Damp Proof Course. A bit more expensive than in Oz, but WTF, don't need much of it and its a Fkn Good investment
150 mm x 8 meter Roll - US 22 or TB 713 per Roll (4.5 Kgs per Rol)
200 mm x 8 meter Roll - US 29 or TB 940 per Roll (5.0 Kgs per Rol)
PLUVEX No 1 150 mm wide x 8 Meter long
Postby gliffaes » Sat Jun 21, 2014 11:44 am
I often wonder of that "dry tech" roof system would double as a damp course, after all its bitumen on a roll?
Postby pipoz » Sat Jun 21, 2014 4:05 pm
Not a bad idea, will look at it.
I am also looking at a couple of Rockmax and Lanko emulsion membrane products, which might also do the job
Postby pipoz » Thu Jun 26, 2014 6:38 pm
Hi Mike,
I probably asked you before, but
1. What was you roof pitch (Degrees)
2. What was the dimension from you Ground Slab to underside of eave/gutter
Postby Mike Judd » Sun Jul 20, 2014 6:25 pm
Here's the latest photos of the split stone nearly all finished around below window sills. Not very Thai colourful I know, but if they want to paint the house pink/blue and green ,they will have to wait until I drop off of my perch. :lol: :lol: :lol:
End of main bedroom.
Entrance and court yard.
Main bedroom ,right side of court yard.
West side
Back of the house.
