90sqm Bungalow quoted build price 1.29m
Re: 90sqm Bungalow quoted build price 1.29m
Postby Max&Bee-in-CM » Thu Jan 27, 2011 7:26 pm
arranp wrote:Hi, the roof area including overhang is approx 16.8m x 12.2m, using CPAC tiles if costing between 1500-2000 m3, how can the cost be calculated ? including the steel trusses.
Regards
Arran.
I can answer the labour component:
roof metal installation is between 50 and 60 baht per sqm, so for you should be between 10248 and 12297 baht.
roof tile installation (including aluminium foil) is 18 baht per sqm, so for you should be 3690 baht.
Note that the measurement are 2D, they need to be converted to 3D, so add another 10%.
Maybe someone else can help on calculating the number of tiles needed....
"Toys & Fun with Ely & Ela"
Max&Bee-in-CM
Postby Max&Bee-in-CM » Thu Jan 27, 2011 7:27 pm
jazzman wrote:you will need to develop good relations with suppliers and service providers if you want free information.
Basically you have to do the opposite of me :lol:
Max&Bee-in-CM
Postby fredlk » Thu Jan 27, 2011 7:55 pm
:lol: I have done my best to do exactly that. :lol:
Postby arranp » Thu Jan 27, 2011 8:13 pm
jazzman wrote:First, there are no cubic measure for roof tiles. You need to think in two dimensions. To get square metres, you multiply the length by the width of an area. Standard CPAC tiles are 11 pieces to a square metre and the standard ranges cost from about 10 to 15 baht each, so that's nothing like your baht 1,500 per square metre. Your roof is straightforward. Use triangles from the plans you have to calculate the total area. The same way, you will calculate the length of the steel rafters, purlins, and queen posts. then you can work out the quantity and the cost. A professional builder will calculate all this for you, but you will need to develop good relations with suppliers and service providers if you want free information.
Thank you <edit - name removed; do not post names of members and do respect their privacy - fredlk>
arranp
Postby jazzman » Fri Jan 28, 2011 7:49 am
<edit - removed reference to commercial member's company and flamish remarks - fredlk>
Postby arranp » Fri Jan 28, 2011 3:52 pm
jazzman wrote:<edit - removed reference to commercial member's company and flamish remarks - fredlk>
The text has been edited before I had a chance to read it, however if it was a positive statement, I would be happy to recieve it via my email address.
arranp
