Hinge Sizes internal doors
Postby gliffaes » Thu Jul 28, 2011 2:23 am
Anyone know the standard hinge sizes in Thailand for internal doors?? is it the same as the UK ie 75mm by 50 mm??
Assuming doors no heavier than 25kg and use of 3 hinges
Re: Hinge Sizes internal doors
Postby little john » Thu Jul 28, 2011 10:49 am
All are doors have 4 hinges 4 cm by 10 cm.
little john
Postby MGV12 » Thu Jul 28, 2011 11:22 am
little john wrote:All are doors have 4 hinges 4 cm by 10 cm.
Really depends on the size and type of door.
Ours are solid teak, therefore a lot heavier than the average British door, and the same as Little John's
That's fairly common but there is a vast range if you go to the right stores.
Postby gliffaes » Thu Jul 28, 2011 12:54 pm
cripes are they made of lead?
Postby little john » Thu Jul 28, 2011 12:57 pm
LOL no we just had a good builder i think.
little john
Postby fredlk » Thu Jul 28, 2011 1:29 pm
Same same, no lead:
Postby splitlid » Thu Jul 28, 2011 1:53 pm
3 x 4" hinges on solid doors are no problem, bottom one 8" up. top one 6" down.
standard.
splitlid
Postby MGV12 » Thu Jul 28, 2011 2:35 pm
splitlid wrote:3 x 4" hinges on solid doors are no problem, bottom one 8" up. top one 6" down.
standard.
True if he buys decent quality hinges himself.
Otherwise the 'standard' here is usually four.
Postby gliffaes » Fri Jul 29, 2011 1:04 pm
Ok Thanks guys 4 seems way over the top I normally put 3 to stop doors bowing in the middle so how about internal ( note internal) door thickness there??? 35mm as an average?
How thick are your internal doors? UK normally 35mm thicker for external doors but its the ointernal that ineterests me. I can get good quality ball bearing hinges in Stainless steel here for about 200 baht a pair.
Postby geordie » Fri Jul 29, 2011 2:24 pm
I bought some really nice stainless hinges from Screwfix for the brothers boat he had previously fitted from B&Q so called stainless with steel screws ? within a year the hinges from B&Q had tarnished and the screws were just a lump of rust Its the quality of the stainless over there that is a bit dubious but its no different here if you are not careful definately get screws with them
Postby gliffaes » Fri Jul 29, 2011 10:20 pm
geordie wrote:I bought some really nice stainless hinges from Screwfix for the brothers boat he had previously fitted from B&Q so called stainless with steel screws ? within a year the hinges from B&Q had tarnished and the screws were just a lump of rust Its the quality of the stainless over there that is a bit dubious but its no different here if you are not careful definately get screws with them
Yep stainles screws as well or a waste of time really. am looking at Dale stainless hinges with screws in the UK
Postby gliffaes » Fri Jul 29, 2011 11:08 pm
Meant to add but what thickness are your internal doors?? as its no use me buying 4 inch (100mm) hinges that are 76mm wide if the doors are standard 35mm thick as theyll be too large "internally"
Return to windows and doors
