Insulating wooden house questions
Postby fredgallaher » Fri Jan 07, 2011 2:01 am
I'm purchasing a teak wood home in Phrae. The house is double walled but not currently air conditioned. I anticipate taking down the interior wall and installing fiberglass insulation. I also need to do the ceiling and install windows. Any suggestions on what to do and what not to do would be appreciated.
Fred
fredgallaher
Re: Insulating wooden house questions
Postby pattayapope » Fri Jan 07, 2011 10:18 am
Fred
Sounds like an interesting project maybe you sould start a thread on the building story forum and post some pictures of the place. One thing for sure if you are going to do major rework on the inside I would look at redoing the electrics and plumbing.
Postby geordie » Sun Jan 09, 2011 5:12 am
sorry fred i meant to reply earlier i wanted to do similar with the in laws house and was advised not too
what i had planned was to place f/glass wool between the walls and also the plastic foil/film then plasterboard over it
the wood breaths too mutch for just f/glass so the idea was staple the foil to the wood first then f/glass wool then plasterboard or plywood
having been shot down in flames by the Thais in laws i ended up replacing the house with concrete which is aparently now too cold ????
I was after a bit of quiet as well the house is in the village and the chickens/dogs/motorbikes
24 hours a day can be a bit tedious especially at night when you are having trouble getting off to sleep anyway
Postby fredgallaher » Mon Jan 24, 2011 12:02 pm
We got the house and we are in the process of having the downstairs and outside refinished. Its taking about 3 weeks to do but its looking really good. As for the insulation, I going to do the ceiling for sure with fiberglass. I think I can get it with reflective foil on top. The wall are all double walled and beautifully finished, so I reluctant to pulling the walls down. Since we plan to extend the master bedroom, I might just insulate the MBR for now. We have 900 sq ft upstairs with 2 bedrooms. I plan to install 4 AC units, but I'm not sure how many BTUs.
We wont be making a permanent move until next year, so we have time to work out the details.
I'll send pictures later when they take down the scaffolding.
Fred
fredgallaher
Postby geordie » Mon Jan 24, 2011 4:46 pm
i look forward to seeing the pictures as i am sure do all the members
The problem with wooden houses is they let air through too easily allowing hot air in and cool air out as you say the house is beautiful and i respect your choice of not wishing to destroy the look it just means higher cost and less efficient air con good luck and don,t forget the pictures
Postby runker » Wed Apr 20, 2011 10:29 pm
You could drill holes between the studs and blow in insulation that way.
runker
Postby geordie » Thu Apr 21, 2011 6:19 am
Can you get the blown insulation over there ?
