Pump(s) and filter for overflow pool.
Postby Breizh29 » Sat Mar 04, 2017 12:50 pm
Hello everyone,
I have a little trouble calculating my needs in pump(s) and filter of my overflow swimming pool under construction. :roll:
I would like mirror pool owners to share their configuration if possible and indicate whether they are experiencing problems or not.
I thank you in advance :wink:
Breizh29
Re: Pump(s) and filter for overflow pool.
Postby Klondyke » Wed Mar 08, 2017 7:54 pm
My experience:
There are diagrams and clever schemes for dimensioning of pumps and filters. The pump capacity (as printed on its label is further reduced by the resistance of the pipes (diameter and length, number of elbows), check (return) valves, outlets jets, number of sucking intakes, resistance of the sand filter, height position of the pump. Different pressure conditions (and so the flow) are when inlet to the pump only from the pool bottom or only from the OF tank, or from skimmer(s).
For my 50,000 m3 pool I have bought my filter in GH (7,500B) and the pump (7,500B) at a (not pool) pump specialist (GH also have a similar pump). The pump label shows a range of 4 - 24 m3/h (with max H 16m), 1.1 kW (1.5HP), it gives me some 12 m3/h, roughly checking, I should better have the piping with a larger diameter.
I do not think that I would fare better when buying at a pool specialist for some 5fold price. The pump is running 4 - 6 hours every day, keeping the water clear without much chemical throughout the year. With a smaller pump the water exchange can be achieved by a prolonged filtering. The minimum and maximum of the necessary filtering time can be tested, whether a difference will be apparent.
Postby Breizh29 » Thu Mar 09, 2017 8:16 am
Klondyke wrote:My experience:
There are diagrams and clever schemes for dimensioning of pumps and filters. .........
Please Klondyke, where can I find these diagrams and clever schemes?
Breizh29
Postby Klondyke » Fri Mar 10, 2017 12:52 pm
I used to see it when browsing sites dealing with swimming pools and pumps. Try to google.
Postby jazzman » Sat Jun 10, 2017 9:18 pm
It's not rocket science - at least when one can get the information from the real experts and not those who are just interested in selling the biggest and most expensive pumps and filters.The state laws of two different developed countries who have states in tropical climates, the USA and Australia, stipulate that for commercial and public pools (which also means tiny pools behind small hotels and guesthouses), the pool volume must be 'turned over' once every 24 hours in not more than 6 hours pumping time.
The calculation just requires some elementary school math: just multiply l x w x d (in metres of course) to get the pool volume, add the volume of the balance tank, and divide by 6.
That will give you the required flow rate in m3/hr. A good then pool website here in Thailand will state the flow rate of the pumps and filters they have on offer. The flow rate of most most pool pumps is quoted at a 4 - 10m 'head'. Pool pumps (generally up to 1.5HP) come with 1.5" ports for the 1.5" PVC pipes used in smaller pools, and 2" ports on pumps over 1,5HP for larger pools. Filters should obviously match the flow rate of the pump, and the pipe size.
Good pool pumps from a recognised brand from a respectable pool firm will certainly not be five times more expensive than the ones in GH. Slightly more expensive, yes, but the quality will be infinitely better and if looked after they will last for 10 - 15 years.
Postby Klondyke » Sun Jun 11, 2017 10:08 am
jazzman wrote:Good pool pumps from a recognised brand from a respectable pool firm will certainly not be five times more expensive than the ones in GH. Slightly more expensive, yes, but the quality will be infinitely better and if looked after they will last for 10 - 15 years.
You might be right, not always five times. However, you will be lucky if you find a pump (at specialist shop) cheaper than three times more expensive. And that my (cheap) pump 1.1 kW (1.5HP) motor was already re-winded by a village people because of being flooded and again being run too early afterwards (in my care). After 5 years still running.
And the prices of filters and other equipment?
the USA and Australia, stipulate that for commercial and public pools (which also means tiny pools behind small hotels and guesthouses),the pool volume must be 'turned over' once every 24 hours in not more than 6 hours pumping time.
In Europe (esp. Germany) they stipulate 2 exchange daily what is really exaggerated. I say I exchange only the water used, the unused (untouched) water I keep aside (just kidding).
I have many times experienced different time frames of the filtering (either intentionally changed or just incidentally), no real visible difference. Of course at the water that was clean and clear over a long period, 1 - 2 day fallouts do not matter.
Of course when the water starts be troubled, either by algaes and/or by iron (rediscovered by too much chlorine) the curing will get the best results by a prolonged filtering and a frequent backwashing of filter - sometimes twice a day. And if you can observe the backwash drain water you will see (and be satisfied) how much you are getting off the dirt.
BTW, as you mentioned "for commercial and public pools", this is a usual stipulation by the pool shops, not considering (and humble mentioning) that the private MickeyMouse pools do not need such overcare. Quite different conditions for our daily swimming (how many minutes per day?) against public pools where hundreds of uncontrolled people and kids come throughout the day.
Postby jazzman » Sun Sep 17, 2017 12:17 am
Klondyke wrote:
BTW, as you mentioned "for commercial and public pools", this is a usual stipulation by the pool shops,.
No, not pool shops. These are government requirements based on scientific research.
Postby Klondyke » Sun Sep 17, 2017 8:27 am
Any government requirements based on scientific research for private (MickeyMouse) pools?
Postby Klondyke » Sun Sep 17, 2017 10:02 am
Dimensioning diagrams for pumps can surely help for a pump selection. However, there are always many factors correcting the calculation we hardly be able to determinate. Hence, we will precisely calculate with inaccurate figures.
The correcting factors are the lengths of the pipes, their dimensions, number of elbows, number of valves. Then the resistance of the sand filter (its size, sand dimension). Then the location of the pump, its height against the pool water level.
So, I doubt that such pump dimensioning will bring something, rather a headache. The purchase will be decided as what is available in the near area and how much I want to spend. If I buy a stronger pump, I can recirculate less hours daily, with weaker pump more hours. So, at the end of the day the same results for me, in m3/day recirculated and in kWh/day spent either.
In my thread about affordable pool I have mentioned the pump I bought some 7 years ago at a pump shop (not pool specialist for 7,500 Baht. That pump was years ago flooded, then re-winded, still working. A similar pump I saw at GH, however, they do not sell it separately, together with a small (useless) filter for 11,500. Still there, they have not changed their sortiment over years, don't sell separately.
Just last week I was passing by the pump shop who sold me my pump, asking what is available? Yes, the same pump, just 1,000 B more (8,500) with a new name, exactly the same shape, label and outlets (2"). I bought it to have a spare, I am hearing my old pump much more than before, the bearings will need to be exchanged. Within 5 min. to have it exchanged.
Old pump (ROWAN):
New pump (TORQUE):
Postby jennifer1234 » Fri Nov 03, 2017 6:22 pm
Hi Breizh29,
One of my friends has a swimming pool in their home, he got his filter pump from <advertising link removed - Mod> and it is very good.
This site has a very good collection pool accessories.
You should once visit here.
jennifer1234
Postby jazzman » Wed Jan 10, 2018 9:18 am
Technology changes and improves over time and prices of good quality equipment have actually gone down significantly since I started this swimming pool forum on CTH many years ago.
The latest generation of pumps, at much the same prices of traditional pool pumps are now on the market which claim to deliver up to half as much more power, e.g. a 1HP pump would theoretically replace a 1.5HP pump. For larger pools, variable speed pumps may also be a worthwhile alternative.
Solar fed pumps are also becoming increasingly popular and take their current direct from the PV panels through a controller without the need of expensive batteries, but these systems are still relatively expensive; again, a reasonable consideration for larger or commercial pools where budget is less of a constraint.
When considering pumps, examine the market here in Thailand very carfully, there are currently only three brands that have a genuine customer and product support here, and that suppport is not offered by every retailer of those brands. A good pump should last for many years - as long as 10 or even 15, but the shaft seals, and sometimes the impeller, may need replacing and you need to be sure thay will be available, and not as in the case of the well kown good quality Poorite brand which went into liquidation leaving even no guarantee support for their products.
If you are having a pool built, be sure to ask your pool constructor what brand and model he intends to install (it may be old stock of obsolete models, or cheap Chinese copies, and in some pool shops too), and that it is correctly matched for the pool volume.
Postby Klondyke » Wed Jan 10, 2018 7:37 pm
It has to be considered that many renowned professional companies selling Chinese made products under their good name and under their good price. How do you want to check where the product was manufactured? What do you think the many container ships - each with 5,000-20,000 container units arriving daily to EU and US ports - are carrying?
Anyway, as I have posted here, I am using the Chinese products (2 - 3 times cheaper than from the genuine companies), for my swimming pool in operation over 12 years, the pump sometimes even flooded by my own contribution, all that making my DIY pool ready and crystal clear (without much chemicals) throughout the whole year for my daily healthy swimming.
