My infinity pool
Re: My infinity pool
Postby Rdteth » Tue Jan 17, 2017 7:43 pm
Guess this is just the blinding layer.
The pipes will come on top of this concrete layer in between the rebar-layers. I guess
Rdteth
Postby Breizh29 » Wed Jan 18, 2017 9:05 am
Rdteth wrote:Guess this is just the blinding layer.
Hello Rdtech
Yes you're right. I called it a slab of cleanliness!
I assumed my english is not top but I cannot do better now! :roll:
Rdteth wrote:The pipes will come on top of this concrete layer in between the rebar-layers. I guess
You are right again :wink:
My contractor is a professional who has already done many swimming pools. I think he knows his business and I cross my fingers!
We have already used its services for the system of filtration of the water that we draw from the underground water table.
Breizh29
Postby Rdteth » Wed Jan 18, 2017 7:27 pm
Thanks Breizh29 for your confirmations.
Hope you follow my thread as well.
Soon I will update. All the steelwork is finished now and the wall for the spa almost done too. Right now putting in the jets.
Rdteth
Postby Rdteth » Wed Jan 18, 2017 8:01 pm
Got a question for you too:
You say you are building an infinity pool. Which in my humble opinion means you have a side or sides where the water will fall in a lower tank or gutter giving an effect like the pool doesn' t end but goes on in the scenery. In your drawing in the very first post i see an overflowpool with a gutter all around except at the spa. What is your idea behind the design?
An infinity pool also has all other sides significantly higher as the "infinity wall (s)". ?????
Rdteth
Postby Breizh29 » Thu Jan 19, 2017 8:48 am
Hello Rdtech,
 My pool will have a gutter all around it except around the spa. This one will be on-high and will overflow in the pool. The gutter will drain into the buffer tank which will be located under the technical room.
In answer to your question I will say that a real mirror pool (infinity pool) overflows everywhere. If it is a partial overflow pool, wells on the other sides will be higher than the sides has overflow.
I followed the construction of your pool but I see that you have not posted anything for more than a month. Looking forward to seeing more ... :D
Breizh29
Postby Breizh29 » Thu Jan 19, 2017 8:47 pm
Breizh29 wrote:Hello Rdtech,
In answer to your question I will say that a real mirror pool (infinity pool) overflows everywhere. If it is a partial overflow pool, walls on the other sides will be higher than the sides with overflow.
Oups!!!
Breizh29
Postby Breizh29 » Fri Jan 20, 2017 1:32 pm
Hello everyone,
It is now possible to click on the photo to have a picture of better quality
The basinl on-high came to complete the pool. It will overflow in the main basin.
The first sheet of reinforcing bars for the slab and the walls is in progress, DB12 will be used is used.
Pipes from 2 " to 13.5 are used.
Breizh29
Postby Breizh29 » Fri Jan 20, 2017 7:42 pm
The host site I try to use deactivates the photos depending on the size, I put the last photo again
Breizh29
Postby Breizh29 » Sun Jan 22, 2017 8:22 am
Work on the pool is progressing. The two layers of reinforcement bars are practically completed. The first sheet of the walls and the spa is also finished.
Today is nonworking day because of lack of rebar!
Breizh29
Postby olavhome » Sun Jan 22, 2017 3:18 pm
Look like they are doing good work with the rebar.
Hopefully pool finished in march when the hot season come :D
olavhome
Postby Rdteth » Sun Jan 22, 2017 5:30 pm
You will put 1 layer of steel in the walls?
Rdteth
Postby Breizh29 » Sun Jan 22, 2017 5:42 pm
olavhome wrote:Look like they are doing good work with the rebar.
Hello Olavhome,
I also hope they do a good job with the rebar! My brother-in-law who knows under construction but no pool comes regularly in the evening when the team finishes working and not to wrinkle and he has nothing to complain about.
The team that makes our pool told us that our is the seventh of roughly similar shape they build.
Today the reception of young trunks of eucalyptus and other forms of wood that will certainly serve for the shoring of the formwork during the pouring of the concrete for the walls.
The formwork panels for the inside part of the walls also arrived there A few days.
Breizh29
Postby Breizh29 » Sun Jan 22, 2017 6:14 pm
Rdteth wrote:You will put 1 layer of steel in the walls?
No, 2 layers but lack of rebar. Have to wait tomorrow! :(
Breizh29
Postby Rdteth » Sun Jan 22, 2017 7:29 pm
just a quick look.
as per 22 01 17
Better and commented will follow soon.
Rdteth
Postby Breizh29 » Sun Jan 22, 2017 7:42 pm
Rdteth wrote:just a quick look.
I look forward! :wink:
Breizh29
