terrazzo swimming pools
Re: terrazzo swimming pools
Postby fredlk » Thu Mar 25, 2010 10:40 am
I think I have all my answers now based on the above explanations and experience.
I am hoping for my whites to stay white - unlike when I do the washing :lol: - and so I think that this might be yet another reason for me to NOT use it for my swimming pool.
I will be going for this effect (also in Phuket):
Thanks to all of you.
Postby grant » Thu Mar 25, 2010 10:48 am
fredlk wrote:I think I have all my answers now based on the above explanations and experience.
It's a beautiful looking pool but good luck with keeping it white. It will be a real challenge here unless you do all the pool maintenance yourself :D
grant
Postby fredlk » Thu Mar 25, 2010 11:05 am
grant wrote:... good luck with keeping it white. It will be a real challenge here unless you do all the pool maintenance yourself :D
The pool in my build will be at house level and plants and flowers will be forbidden up there.
That way I hope to solve the problem of too many excess leaves and some of the airborne sand and soil.
I plan to employ a Kreepy Krauly for the daily maintenance, but I suppose I have to admit now that I have been warned. :)
Postby Nawty » Sat Mar 27, 2010 10:09 am
Buy a very strong scrubbing brush, buy 12 actually, 1 for each month and a goggle and snorkel. In fact some scuba gear would be better.
Good luck.
But does look nice.
Nawty
Postby fredlk » Sat Mar 27, 2010 11:49 am
Nawty wrote:Buy a very strong scrubbing brush, buy 12 actually, 1 for each month and a goggle and snorkel. In fact some scuba gear would be better.
I was thinking of letting my neighbours, the Royal Thai Navy's diving team, use my pool for practice ... and clean it while they're at it. :idea:
Postby christopher » Tue Mar 30, 2010 8:32 pm
I have a 10,000liter terrazzo pool in which the PH rises from 7,5 to 8,0 every day The total alacalinity is between 80 to 100
I have been told that the reason for the increasing PH may be the Terazzo. Does anyone else have a similar problem?
christopher
Postby fredlk » Tue Mar 30, 2010 9:36 pm
christopher wrote:I have a 10,000liter terrazzo pool .....
I know this is not answering your question and I don't think I know the answer, but where are you writing from?
Would you mind posting a photo of your pool?
Maybe Grant has an answer for you as he seems to be the only other person here with a terrazzo pool.
Postby grant » Wed Mar 31, 2010 8:44 pm
christopher wrote:I have a 10,000liter terrazzo pool in which the PH rises from 7,5 to 8,0 every day The total alacalinity is between 80 to 100
I use an ionization/oxidation system in my pool with no chlorine so my pH needs to be in the range of 6.8 - 7.2. When I first started up the system 9 months ago, I was having the same problem with rising pH and had to add acid every day. This is a common problem for gunite, concrete and terrazzo pools and after a lot of research on the web, the general consensus is that it can take 6-12 months for the pool's pH to stabilize. My pool is 106,000 liters and I now add about 800 ml of acid two to three times per week to keep the pH below 7.2, about half of what I was adding in the beginning. Other than adding calcium once a month, that's the only maintenance required apart from cleaning.
grant
Postby old_expat » Thu Jun 03, 2010 3:19 pm
I love terrazzo floors and always thought they were extremely durable, until a couple of days ago. I stayed overnight in a newish apartment building in Korat Town .. the Ratchadakorn Mansion. I was admiring the terrazzo floors and noticed a blemish spot about the size of a tennis ball. It was apparently made by condensate leaking from the air con.
The leak had eroded the surface more than a mm deep and was absorbing water. The surface was obviously rough.
Was the mix probably wrong? Wrong sealer applied?
old_expat
Postby grant » Thu Jun 03, 2010 3:27 pm
old_expat wrote:I love terrazzo floors and always thought they were extremely durable, until a couple of days ago. I stayed overnight in a newish apartment building in Korat Town .. the Ratchadakorn Mansion. I was admiring the terrazzo floors and noticed a blemish spot about the size of a tennis ball. It was apparently made by condensate leaking from the air con.
Many Thai contractors do not bother to seal terrazzo but simply buff it up with a coat of wax to make it look good. Wax does act as a temporary sealant but not a very good one and it needs to be reapplied frequently. Adding a floor hardener and a sealant is the best way to preserve and protect terrazzo.
grant
