A truly professional pool building company will put down either piles or footings with an H-shaped beam, or for a longer pool, a cross-bar beam every 3.5 - 4.5 metres. They will never just pour a slab without any underpinning. If you a re doing it yourself, you can take the risk. I built my first pool in 1974 without absolutely any knowledge whatsoever - it didn't even have any plumbing or a filtration system as it was expected to have to change the water every couple of weeks! It had a flat concrete bottom and no beams or footings, but it is still in use today in spite of extreme seasonal changes in temperature. It is drained throughout the winter. (Hambühren, Landkreisreis Celle, near Hannover, Germany).
Don't forget the extra cost of rebar in the footings and beams. A standard 20 cm thick floor plate should have two levels of 12 mm rebar (DB12) laid in a 20 x 20 grid. 'bar-chair' spacers of RB9 keep the two levels 10 cm apart.
Don't forget the water-stop in the join between the floor plate and the concrete walls, and excercise all the recommended caution with all the pipes and electrical conduit that goes through the concrete walls - there's a right way and a wrong way of doing this.
Correctly calculate the capacitly of the pump and filter that you will need - and DON'T get ripped off with the price: around 22,000 baht should be the absolute maximum for a complete pump and filter combination pool your size. be absolutely sure to use special 13.8 grade PVC piping (NOT 8.5!) and accesories throughout, use wide radius bends (not 90° angles), and use the special glue, not that ordinary liquid stuff for standard PVC pipe. Break the glaze with very fine sandpaper on the outside and inside of all part to be joined before applying the glue. he glue sets immediately - you don't get a second shot to tweak anything. If you can afford an extra 3,900 baht, used crushed SO2 crystalls filter media rather than silica sand, right from the very start.
Pressure test all your plumbing before you backfill any dirst.
Finally, read ALL the threads in this swimming pool forum
