concrete fence
concrete fence
Postby paulthai » Fri Oct 14, 2016 4:41 pm
hallo,
we would like to make a concrete fence 100 m long high 1,5 m.
location pakaat in province buengkan.
any sugestions, builders,prices?
thanks
paul
paulthai
Re: concrete fence
Postby Sometimewoodworker » Fri Oct 14, 2016 8:14 pm
Spend some time reading the building threads here first. Your question is probably already answered.
Re: concrete fence
Postby pipoz » Fri Oct 14, 2016 8:40 pm
paulthai wrote:hallo,
thanks
paul
Hi and this is from my Build, "Udon Thani Happy House" Pages 46-48, back in May 2016, for a concrete beam & post fence with block work wall, works out to TB 1250 per m2 or TB 2500 per linear meter
If you build your wall (1500mm high) in concrete (say 120 mm thick) with mesh reinforcement + a few bars, but use good steel wall forms (rented ones), so that you don't have to spend on render to walls afterwards, my estimate is it will cost you close on TB 2500 - 2800 per meter length.
From my Build: "Starting the last of the external fence/wall on the South side. Have approximately 80 LM to complete x 1.8 - 2.0 meters high. Bought the Posts (2.5 long), Blocks (400 x 200 x 70 mm wide), Tie Beam Reinforcement (DB12 Bar & R10 Ligatures), Cement, Gravel and Sand. Spent TB 112,000, as my initial estimate of what I think I will need, which works out to around TB 1,400 per linear meter for Materials Only (Excluding render).Will deal with the labor cost on a daily hire basis. Estimate it will take 4 workers x 2.5 weeks = TB 36,000 (approx) + TB 2000 (to clear the existing fence and growth)
Estimate all up cost around TB 150,000 for around 80 LM + the cost of the Render to one side afterwards"I would say the final cost was closer to TB 170,000 + Cost of Render = TB 200,000 All up for 80 meters
