M2 rendering
M2 rendering
Postby Sunpax » Sun Feb 20, 2011 1:24 pm
How much ciment do I need for 1 m2 render walls inside and outside ?
for concrete wall is one bag by m2...but to "shap" how many bag "type 1" (95 bahts) do I need for 1 m2 ?
thanck's
Sunpax
Re: M2 rendering
Postby geordie » Sun Feb 20, 2011 3:38 pm
Sunpax wrote:How much ciment do I need for 1 m2 render walls inside and outside ?
thanck's
SUNPAX there is not an answer to your question because there are variables that will stuff the calculations
With rendering you are using it to straighten and parfect the blockwork so any imperfections will reflect in how mutch material you use
a slight thickening will throw out the calculations the same
My suggestion would be to look through and read a few of the posts regarding plastering and render there are lots of them and that will give you and idea roughly
there is a search facility at the very top of this page which will if you type in plastering and rendering take you to the section you need and give you a better idea of the process
One thread suggests between .016and.024 of sand and 6kg-8.5kg of cement one answer would apply to rendering on a smooth straight surface the other would apply to real world conditions
the answer is give it a guess after reading a few threads most builders will do that purely becase of the previously mentioned variables
also take a look at jazzmans breakdown on cost of a wall where he has costed out a section of wall its acurate enough for estimating and he updates as prices rise
Re: M2 rendering
Postby Sunpax » Sun Feb 20, 2011 5:15 pm
thanck's
Thanck you ! it is what I was looking for !
And again I see that my BOQ is totally falsch ...grrr
because it say i need one bag for one m2 ! 680m2 x 95 = 64,600 bahts ! without labour cost !!!
Sunpax
