Long run, village supply 1/2"!
Postby nlimcm » Fri Jul 14, 2017 10:47 am
Hello,
I'm struggling to decide what size pipe to use - and any plumbing advice would be greatly appreciated!
We have village water which comes in on 1/2 pipe -this is our only access and we have a 1/2 inch meter. The house will be approx 120m away, and we will probably have a tank and pump for the house supply.
My current question is what size pipe should I use? I've read lots about pressure and flow, and I understand bigger pipe equals less pressure loss over a distance (http://www.druckverlust.de/Online-Rechner/dp.php). But where our supply is small, what impact does this have? I'm also unsure what the village water supply pressure is to start with.
So, should I use a bigger pipe after the 1/2" meter?
Or make a concrete ring tank and then use a bigger pipe from there?
Right now we need to water trees etc and provide water for the build.
Many thanks
Natalie
nlimcm
Re: Long run, village supply 1/2"!
Postby Klondyke » Fri Jul 14, 2017 6:42 pm
You cannot rely on a steady water pressure from the poor village system, especially when fed by 1/2" pipe.
You surely will need a storage tank at your house with a ball valve that shut off prior overflow (usually included in the plastic tank 1,000 - 2,000 L bought at GH or Thai Wasadu). From there on an automatic pressure pump keeping the pressure in the house water system.
Postby mikenot » Sat Jul 15, 2017 5:57 pm
You will not gain any pressure by installing bigger pipe, so settle for the 1/2 inch and just let your tank fill gradually, with a pump to supply pressure into the house. Use the money you save by buying 1/2 inch pipe to get a better grade PVC !
mikenot
Postby Sometimewoodworker » Sun Jul 16, 2017 7:40 am
mikenot wrote:You will not gain any pressure by installing bigger pipe, so settle for the 1/2 inch and just let your tank fill gradually, with a pump to supply pressure into the house. Use the money you save by buying 1/2 inch pipe to get a better grade PVC !
While you will not gain pressure gain by installing a bigger pipe you will certainly loose much less.
I have chosen to use 32 mm ppr throughout our system and though it's a little bit more than double the price of ½ inch as a relative cost it is insignificant.
http://www.calculatoredge.com/mech/pipe%20friction.htm
¾ inch
1 inch
½ inch
Postby nlimcm » Fri Jul 21, 2017 9:32 pm
Thanks for the responses.
Can anyone confirm what happens if I just go from the current 1/2" supply to 1" pipe across the land?
If not I will go with 1/2" pipe from the meter to a tank near the gate, then 1" pipe across the land to where the house will be.
nlimcm
Postby Sometimewoodworker » Sat Jul 22, 2017 6:30 am
nlimcm wrote:Thanks for the responses.
That is easy.
You will have vastly lowered friction losses in that pipe. For very low flow rates it may not be a big gain
Postby Klondyke » Sat Jul 22, 2017 8:07 am
One of the examples of inverted practice in Thailand: In many cases the investment is oversized (e.g. building structures), in many cases it's undersized (always water system).
Even the logic: I was once persuaded that the 1/2" is better, resulting in a higher pressure. :shock:
Postby nlimcm » Sat Jul 22, 2017 8:40 am
Thanks - a tank and 1"pipe it is then!
nlimcm
