pressure pump for guesthouse
Anything to do with the subject of water or plumbing. Any type of well (hand dug wells, drilled wells, etc.), plumbing (but not swimming pools) or any other discussion related to water.
Re: pressure pump for guesthouse
Postby Sometimewoodworker » Tue Apr 25, 2017 10:44 am
Trikke76 wrote:
anyone with good experience with a electric water heater for the shower ?
or brands to avoid as hell ?
My personal preference is the Sharp WH-T67DP it has an exact temperature readout in degrees C rather than a dial that sets a random temperature somewhere between cold and cook, you can change the default temperature, it is a 6,000W unit so good for the cold season, cost is 5,350 + about 250 by EMS from smtv, much more from other suppliers.
We have had a 3,500W Sharp unit for the last 10 years the only drawback with tat old one is that in the cold season it can't heat the water over about 35 degrees. So that is why we are getting the bigger units.
Postby Trikke76 » Wed Apr 26, 2017 2:32 am
Thx for the info
The site you mention smtv is it a good reliable webshop ?
No idea as what site is reliable and cheap here in Thailand.
Trikke76
Postby Sometimewoodworker » Wed Apr 26, 2017 4:46 am
Trikke76 wrote:Thx for the info
We bought two of the Sharp water heaters from them, fast delivery. You need a Thai speaker SWMBO called them then contacted them on Line, I transferred the money, about 3 days later the heaters arrived.
Return to water and plumbing
