Floor drain P-trap
Re: Floor drain P-trap
Postby canopy » Fri Feb 13, 2015 3:52 pm
scudman wrote:He wants to run the two floor drains together and then to one P-trap before it goes to the sewer
Note there is a maximum distance from drain to trap. It depends on a few things and will most likely fall well below 2M. Exceeding it on either one you can look forward to odors and poor drainage. And what is the venting design?
canopy
Postby scudman » Fri Feb 13, 2015 4:50 pm
He is going to put an example together for me, ( I have 6 baths to do), but I believe it will be under 2 meters. Venting was planned at the septic tank, which I believe to be the common practice here.
scudman
Postby Sometimewoodworker » Fri Feb 13, 2015 7:39 pm
Venting at the septic is may not be needed depending on the design of your waste water system
But you must vent after each P-trap anyway. If you don't there is every chance that most of them will not work as the water that needs to be in them will be siphoned out.
It looks as if your builder has no idea of how to design a western plumbing system so is adding your "strange" plumbing, but not doing the other bits that are needed.
http://www.id-sphere.com/2010/01/tips-o ... ils-pipes/
http://www.dummies.com/how-to/content/f ... lines.html
http://m.wikihow.com/Vent-Plumbing
Example DWV system
Postby BKKBILL » Fri Feb 13, 2015 8:30 pm
Thing is in Thailand under normal practice you will have two drainage systems. One for toilets, urinals and such (black water) the other sinks, showers (grey waste) so getting a vent system as shown will probably not happen nor is it necessary IMHO. These different piping systems don't run to the septic tank just the black waste does or at least should.
I know it's not western venting but the systems are not the same. This has been discussed on CTH many times on many threads all the way up to 3” copper vents.
You should at the least put a “P” trap under each shower and sink.
Postby Sometimewoodworker » Fri Feb 13, 2015 9:22 pm
BKKBILL wrote:Thing is in Thailand under normal practice you will have two drainage systems. One for toilets, urinals and such (black water) the other sinks, showers (grey waste) so getting a vent system as shown will probably not happen nor is it necessary IMHO. These different piping systems don't run to the septic tank just the black waste does or at least should.
Very true.
However one system or 2 the physics don't change. If you don't vent you can easily siphon the water out of the trap.
You may avoid the problem if you use large diameter waste pipe, as it can self vent.
Large and small outlets
Postby BKKBILL » Fri Feb 13, 2015 9:42 pm
True, it is what it is.
A 2" p trap should handle it especially if the strainer has a brass flapper that seals the opening as most of the better ones do.
This is what the ones we use look like.
Bathroom-4-stainless-steel-self-sealing-water-trap-anti-odor-deodorization-type-floor-drain.jpg
Postby Buriram Builders » Mon Mar 02, 2015 7:09 pm
Most any Cotto dealer can sell you a quality "Smart Drain" for your shower. Cotto is not the only brand of this "Smart Drain", but it is a proven product and has been available since at least 2008. I have bought the Cotto Smart Drain in Surin at Home Mart and in Buriram at a Builders Merchants Store. It is less than 700 baht and has lasted over 7 years in my Buriram shower floor. You cut a piece of your floor tile and it installs on this Cotto Smart Drain. It is better and easy to install when building a house in Thailand and harder to do as a minor replacement. I've done both and highly recommend the smart drain as an item to install in every shower when building a house in Buriram or any part of Thailand. The Cotto Smart drain is in a clear box with a red cardboard backing on the box.
The Cotto smart drain is for a shower floor in Thailand
The shower floor drain is in the hand of the Cotto toilet salesman
Buriram Builders
Postby scudman » Mon Mar 02, 2015 7:47 pm
Buriram Builders wrote:Most any Cotto dealer can sell you a quality "Smart Drain" for your shower. Cotto is not the only brand of this "Smart Drain", but it is a proven product.....
BKKBILL wrote:^
Thanks for the suggestions. I will look for these products at my local stores; Thai Watsadu and Home Mart.
scudman
Postby Ians » Mon Mar 02, 2015 8:31 pm
Be aware if you fit a "Smart Drain" prior to a "P" trap it can cause a problem as I have discovered, you can end up with an airlock between the drain and the P trap and the water from the shower doesn't drain properly - in my case I had to drill a small vent hole in the smart drain to allow the air between the smart drain and the P to vent - so in effect if you have a P trap in the line you don't need or shouldn't use a Smart Drain.
I have a couple on floor drain discharging to a general grey water system without any P trap in the line and they do as they are supposed to do.
If no P trap, then the smart drain is an ideal solution in overcoming any smell coming back up the drain.
