gliffaes wrote:does the pump itself have some sort of switch to turn itself off and on
fredlk wrote:gliffaes wrote:does the pump itself have some sort of switch to turn itself off and on
No it doesn't.
MGV12 wrote:Maybe the longer version of Fred's response is or isn't http://inspectapedia.com/water/Well_Pum ... rsible.htm
A proper installation certainly wouldn't blow your cock off
gliffaes wrote:MGV12 wrote:Maybe the longer version of Fred's response is or isn't http://inspectapedia.com/water/Well_Pum ... rsible.htm
Ok Thanks so unless its running open ended ie irrigation it will need a tank .
Ok so my borehole is 25 metres from the house, the borehole will pump straight into a tank first right outside my house what will tell it to stop pumping into the tank , I mean do I need an electrical connection of some sort form the tank back to the borehole other than what I have now in my borehole house as if i do Im gonna have to start digging another trench from the tank back to the borehole......sigh.
A diagram would be good?
MGV12 wrote:gliffaes wrote:MGV12 wrote:Maybe the longer version of Fred's response is or isn't http://inspectapedia.com/wate r/Well_Pump_Operation_Submersible.htm
No doubt it would and in due course Sirineou and others who sit around doing squat all day will provide one.![]()
gliffaes wrote:fredlk wrote:gliffaes wrote:does the pump itself have some sort of switch to turn itself off and on
No it doesn't.
Can u make the answer a bit shorter Fred?
BKKBILL wrote:gliffaes wrote:MGV12 wrote:Maybe the longer version of Fred's response is or isn't http://inspectapedia.com/water/Well_Pum ... rsible.htm
How about this one with everything in the pump house.
http://kwhrmeter.blogspot.com/2013/05/s ... n-and.html
No it doesn't.
