thailazer wrote:Cut some pieces to throw as dog toys but they would burst on impact. Quite unlike the green PP-R pieces which do not get brittle and are much tougher for the dog to destroy.
BKKBILL wrote:thailazer wrote:Cut some pieces to throw as dog toys but they would burst on impact. Quite unlike the green PP-R pieces which do not get brittle and are much tougher for the dog to destroy.
PP-R for dog toys sacrilegious I say.
pipoz wrote:Hi
If I want to use the Annealed Copper Pipe (such as the one that come in the coil back in Oz, available at Bunnings, i.e Syneco or Kembla Copper Tube) for my Bathroom Hot and Cold water plumbing pipework, can I find something similar along with the Copper Fittings at either Global House or Thaiwatsadu or Home Pro etc?
eyecatcher wrote:ps:I went into one store with all the pipes and tubing racked out; and couldnt believe my eyes when I spotted copper pipes ; although stood well back it looked like microbore. Just stood there smiling and then went to check the price.....ooh thats expensive so I picked it up.
it was the copper earthing rod.![]()
really must use my specs more often
BKKBILL wrote:Fusion welded PP-R pipe and fittings are in my opinion superior to a mechanical joint relying on an “O” ring for it’s seal. The fusion joint makes pipe and fitting as one and is the most popular one used here..
I have a Fusion welded you can use.
pipoz wrote:Hi
kmanonmaui wrote:Hello,
Other than cost and availability (which I do understand are big factors) is their benefit to one over the other?
I was planning on running copper, which I am most familiar with. However, someone (not a builder or professional) told me that the minerals in the water in Thailand would deteriorate the copper pipe much more quickly than uPVC or PP-R. I suppose I could run one material for cold and another for hot, if temperature is relevant to the durability and life.
Thanks in advance,
-k-
